Old 08-18-2009, 07:22 AM
Dan H's Avatar
Dan H Dan H is offline
Rep: 10 Posts: 23
Lost in translation here.
$65.00/gal. for epoxy is useless unless you spend $38.00 for hardener. ($103.00)
So when Triump34 says $100.00/gallon, he's buying the hardener also.
I agree with everyone here, leave the polyester on the shelf.
Old 08-18-2009, 08:06 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
1 gal. resin at $65/gal plus 2 qt. hardener at, say, $19/qt = 1.5 gallons epoxy for $103, or $69 per gallon. With a 100% solids epoxy, the harder volume must be added to the resin volume when calculating price/gallon and yield, whereas with polyester, the amount of catalyst used is so small that it can be ignored when calculating total yield.
As PAR has pointed out, a bit of shopping around can net significant price breaks compared to buying a gallon at a time from the chandlery.
Old 08-18-2009, 10:48 AM
Rep: 3125 Posts: 9,395
I quoted prices for both resin and hardener in all the quantities I listed.
Old 08-21-2009, 04:57 PM
old_sailor old_sailor is offline
amateur boatbuilder
Rep: 10 Posts: 11
Par,
Last time I was at Fiberglass Coatings, they had a wole new crew. I didn't see Joel anywhere.
They are not the cheapest, but for seven years I dealt with them because I was building my boat in Dunedin, and they were convienient. Wow! Did I see their prices skyrocket over that time span.
I have had no trouble with their general purpose laminating resin. Time is the only factor.
Old 08-21-2009, 07:42 PM
Yep, FGC,Inc. was sold a few years ago and a lot of the old crew found jobs in other places. They promptly opened another office and prices have changed. I started using them when I moved to St. Pete back in the 80's, but haven't used them for a number of years.
Old 08-21-2009, 10:25 PM
Rep: 527 Posts: 792
I understand that whole business got very ugly with FGCI bringing lawsuits against several of their former employees who went to work for others (for violation of non-compete agreements; very standard; we have them with all of our employees) as the new owners had made continued employment very uncomfortable. I guess the new owners expected them to all go out and flip burgers instead of working in the same field that they had worked in for years.
Jimbo
Polyester over Epoxy - please help Manie B Boatbuilding 3 03-24-2008 06:36 AM
What happens when epoxy and polyester are mixed... cornelldave Fiberglass and Composite Boat Building 2 08-21-2006 09:11 AM
How to tell polyester from epoxy? basstardo Fiberglass and Composite Boat Building 10 02-09-2006 01:16 AM
Epoxy over Polyester Blue Heron Fiberglass and Composite Boat Building 6 12-09-2005 11:48 AM
Epoxy bond to Polyester Ok J Fiberglass and Composite Boat Building 2 04-25-2005 06:18 AM
