I went ahead and asked both
Raka and
Gougeon Brothers about this and they were both kind enough to give some general pointers which are pretty much in alignment with what I've said above. In addition, Gougeon Brothers pointed out that there was an article in the current issue of Professional Boatbuilder (December/January, #74) on page 20 on this very topic - I saw the article on Wave Piercers and must confess that I somehow skipped past the article on integral tanks
For a subscription to Professional Boatbuilder, see their web site at
http://www.proboat.com
Gougeon Brothers also included the following article for reference - I can't find a copy on their web site to link to so I'm sure they won't mind if I attach it for you to look at as well:
Building Tanks with WEST SYSTEM® Brand Epoxy
Wood/Epoxy Composite Tank Guidelines
Builders have successfully constructed tanks for potable water, sewage, gray water, ballast and diesel fuel tanks and a limited number of gasoline tanks using WEST SYSTEM® Brand Epoxy since the early 1970's. The regulatory environment has evolved within the last thirty years and has placed safety restrictions on various aspects of tank building, specifically potable water and gasoline.
U. S. Coast Guard (USCG) regulations, Food and Drug Administration (FDA) regulations, American Boat & Yacht Council (ABYC) standards, and insurance restrictions should be carefully considered by anyone, professional and homebuilder alike, planning to build a composite tank. Tank construction material and construction processes have been investigated thoroughly over the years, and the lowest grief option is choosing a certified tank from a manufacturer. Certified fuel tanks have already been tested in accordance with strict fire and flame regulations, and have proven themselves in the field. Certified potable water tanks have been made to minimize or eliminate extractives.
While professional builders are bound by tough USCG regulations and ABYC standards regarding tanks, back-yard-boat builders have the option to follow or disregard them. If the back-yard-boat builder chooses to disregard the regulations and doesn't sell the boat, the builder meets the intent of the federal regulations. However, once the builder decides to sell the boat, the federal regulations become applicable and must be followed because he/she has built the boat for the purposes of sale. A good reference for individuals building boats for their own use and not for the purposes of sale is the publication, Safety Standards for Backyard Boat Builders, COMDTPUB P16761 3B. This may be obtained from USCG Headquarters or on the Internet; addresses, phone numbers, and web sites are noted in the reference section.
Before using Gougeon Brothers' products in tank construction, we advise that customers review the relevant federal, state and local safety regulations, standards, and recommended marine practices, as well as contacting their insurance carriers for restrictions. A wood/epoxy diesel fuel tank may be an uneconomical choice if insurance premiums increase or if state licensing/federal documentation problems are encountered.
General Wood/Epoxy Tank Construction
Once the epoxy leaves our shipping dock, Gougeon Brothers cannot control how the epoxy will be used. Some customers will use, and have used the epoxy to build all types of tanks. For those who decide to proceed with making tanks, here are some guidelines to help make the project as successful as possible. The key to a durable tank is a thick, well-cured epoxy coating. To minimize long-term corrosion and performance problems, we recommend that the coating be:
(1) slightly resin-rich/hardener-lean, see chart in reference section for maximum ratio
(2) well mixed, scraping sides and bottom of container
(3) elevated temperature post-cured, minimum of 120° F for 4 to 8 hours (after epoxy has cured at room temperature and is hard to the touch)
(4) thoroughly scrubbed with water and a scouring/abrasive pad, rinsed, and dried
The inside of the tank should be treated similar to the outside of a hull. We recommend a minimum of 20-mil coverage for all interior surfaces of tanks. This is similar to the coverage recommend as a "barrier coat" for the exterior of a hull, which is five to six rolled coats of epoxy. After rolling, the epoxy should be brushed out to minimize any entrapped air. Surge baffles should be installed to minimize free surface effect. The baffles should be installed with generous fillets and the fillets should get the same five to six coats of epoxy as the rest of the tank interior.
Any tank openings, such as fill, vent, inspection or clean out, should be oversized and also receive five to six coats of epoxy. We recommend that fasteners be epoxy bonded in place to secure any hardware to the tank or in the construction of the tank. Details of hardware bonding can be found in the WEST SYSTEM User Manual/Product Guide, Catalog Number 002-950 or on our web site noted in the reference section.
Carefully metered resin/hardener ratio is critical to any epoxy's performance. In all projects, with one exception, we recommend dispensing and mixing epoxy at the target ratio within our acceptable range. Tank building is the exception to the rule. When mixing epoxy for tank coatings, we recommend a resin rich/hardener lean mixture at the outer limits of the acceptable range. The table in the reference section notes the acceptable resin rich/hardener lean ratios. Please see sidebar for more in-depth discussion of our recommendation for this type of mixture.
Sidebar: Resin rich/hardener lean epoxy for tank coating
We only recommend a slightly resin rich/hardener lean mixture when dispensing and mixing epoxy for coating the insides of tanks. This is because excess resin in epoxy is less likely to adversely effect the physical properties of cured epoxy than excess hardener. When excess hardener is in the epoxy matrix, it cannot fully react with the resin and will become suspended in the mixture. Because amines (in the hardeners) are water-soluble, they can potentially leach out and cause odd tastes, contaminates in the liquid, and porosity in the epoxy film, among other performance defects. The maximum resin rich ratios noted in the reference section are at the end of acceptable ranges for WEST SYSTEM epoxy. These ratios should not be taken any farther away from the target. These maximum resin rich ratios meet specification to obtain a properly cured epoxy film and to minimize extracts leaching out of the epoxy. When using 300, 301 or 303 Mini Pumps, one way to obtain the resin rich/hardener lean ratio within the acceptable range is dispense the following:
Epoxy Combination......................Pumps Resin..........Pumps Hardener
105 Resin/205 or 206 Hardener..........6........................5
105 Resin/207 or 209 Hardener..........7........................6
Thorough mixing is difficult to achieve because the single resin or hardener components stick or cling to the sides of the container. This is readily seen when tinted epoxy is mixed together. We recommend that a double-pot mixing method be used when building or coating tanks. This is accomplished in two stages. The first stage is mixing the resin and hardener in one container, scraping the sides and bottom. Scraping is key because it incorporates the majority of the single components in the mixture. The second stage involves transferring this mixed epoxy into another clean mixing container. A new stir stick is used to mix this a second time. Any clinging material was already mixed once from the first stage and has a very low potential of being a single component.
A temporary oven or radiant heater can be used to apply an elevated temperature post-cure. A high-wattage incandescent or halogen light bulb can raise the temperature in a tank high enough to do the job. This is often the only way to do an integral tank. However, watch the fire hazard as some light bulbs can get hot enough to cause the epoxy to char or possibly ignite.
Scrubbing with water and a scouring/abrasive pad, similar to 3M's Scotch Brite® pad, removes any surface contamination, specifically any potential amine blush that may form on the surface. Amine blush is water-soluble and can be removed with tap water. The scrubbing action agitates the surface to help remove it. Solvents without high water content don't normally remove the amine blush because of its water solubility. Leave the lacquer thinner, acetone, vinegar, alcohol, and other solvents in the storage bin, use warm water if you need to deviate from the norm. Rinse again with water and dry with paper towel.
Holding Tank and Gray Water Tank Considerations
Sewage holding tanks are Type III marine sanitation devices (MSD) and are regulated under Title 33, Code of Federal Regulations Part 159 (33 CFR 159)-Marine Sanitation Devices. A Type III MSD is considered a certified tank if it: (1) is used solely for the storage of sewage and flushwater at ambient air pressure and temperature; and (2) prevents the overboard discharge of treated or untreated sewage or any waste derived from sewage (33 CFR 159.3, 159.12a, and 159.53). Type III MSDs may not be labeled. For Coast Guard Inspected vessels, the Type III MSD must also comply with 33 CFR 159.97. For the specific tank construction, make sure the internal surfaces are very smooth and that all burrs or wood splinters are removed so they don't cause anything to cling to the surfaces. This should help allow the tank to be cleaned efficiently.
Type I and Type II MSDs are more complex systems and are beyond the scope of this article, please refer to the Code of Federal Regulations for guidance.
We know of no federal regulations or other standards regarding the manufacture of gray water tanks. Use the above general guidelines for construction and you should not have any problem using WEST SYSTEM epoxy.
Potable Water Tank Considerations
We feel that the potential problems outweigh benefits and have adopted the broad policy of not recommending the epoxy for drinking water tanks because of regulatory and safety issues. To date, none of Gougeon Brothers' epoxies meet FDA regulations or any other drinking water certified approval. The major long-term concern with any plastic water tank is extractives leaching out in the water. Off-ratio, poorly cured epoxy can release extractives, as noted above. In the fabrication of water tanks and food handling equipment, the successful use of epoxy requires thorough mixing and adequate elevated temperature post-cure to assure the maximum cross-linking and cure of the polymer. These process controls are not always possible with the home-built tank. Unfortunately, neither Gougeon Brothers, Inc. nor any certification agency can verify the level of quality control exercised in the fabrication of the tank.
What about the builder who weighs the risks and decides to go ahead against our recommendation? For the homebuilder it is a personal choice. In addition to the recommendations in the general guidelines noted above, a builder may want to install an in-line filter to help remove any possible extracts and odd tastes. Professional builders should understand, again, that there are no formal approvals (awarded or pending) for Gougeon Brother's epoxy products for use in potable water tanks. Where certification is required, it is usually application specific. We have looked at the 2000 Title 21 of the Code of Federal Regulations, Part 175.300 (Food and Drug Administration, HHS) and found that the testing is specific for end-use conditions, container sizes, and frequency of use. If you have specific design/use in mind, it may be appropriate to contact the knowledgeable American or Canadian agency to identify their requirements. As with many things, the care used in the construction of the tank is the key to the overall quality.
ABYC also has a section dedicated to the general installation of potable water systems; the specific standard is H-23-Installation of Potable Water Systems for Use on Boats.
Another great agency to get information regarding potable water coatings is NSF International, The Public Health and Safety Company™. They are dedicated to testing and issuing certifications of various coatings and materials for public health and safety. You can get information off their web site to find current products that meet their various standards. Their contact information is found in the reference section below.
Fuel Tank Considerations
Fuel tank building is a controversial area. There are several USCG regulations and ABYC standards governing fuel systems. Actually, the USCG regulations are only applicable for gasoline fuel systems, not diesel fuel. Because of gasoline's lower flash point, higher volatility and combustibility, gasoline systems are more regulated than diesel fuel systems. These regulations are very specific and contain stringent requirements for the fill systems, vents, installation, testing and labeling.
The USCG regulatory information can be obtained at USCG Headquarters and at each Coast Guard District's Boating Safety Division, all of these contacts are noted in the reference section, too. The guiding regulations for gasoline tanks in recreational boating are contained in Title 33 of the Code of Federal Regulations, Part 183.501 through 183.590. The regulations may be found on the World Wide Web at no charge or may be obtained for a nominal fee from the Government Printing Office. These sources are found in the reference section. The ABYC standards for gasoline systems are found in Standard H-24-Gasoline Fuel Systems and H-25-Portable Gasoline Fuel Systems.
Although the USCG doesn't publish any regulations for recreational boat diesel fuel systems, ABYC publishes a written a standard, Standard H-33-Diesel Fuel Systems. It would behoove customers to obtain a copy to ensure all safety precautions and recommended practices are followed.
Conclusion
All types and variations of tanks have been successfully constructed with WEST SYSTEM Brand epoxy and used in the field with great results. However, Gougeon Brothers does not condone or recommend that certain tanks be built because of various issues noted above. In our testing, various epoxy combinations have proven to be resistant to various liquids, including gasoline, diesel fuel, motor oil, potable water, sea water, sewage, gray water, etc. Regarding gasoline specifically, some epoxy combinations are more resistant than others are. With the increasing use of alcohol and other high-tech additives, we are unsure how the epoxy will resist them in the future. We do know that many types of alcohol vigorously attack epoxy, we can only conclude that gasoline with a higher percentage of alcohol may not have favorable results in long-term use.
Before building gasoline tanks and potable water tanks, do your homework and take into consideration the information above. The resources and various agencies noted below should help you make informed decisions regarding tanks and whether or not you should build your own. The final decision to build or not to build rests on the builder, we hope this document helps the builder make sound, educated decisions. As always, please contact the Technical Staff if specific questions arise.
References and Resources:
COMDTPUB P16761 3B
Commandant (G-OPB-3),
US Coast Guard,
2100 Second Street, SW,
Washington DC, 20593-0001,
(202) 267-0984
USCG Infoline: (800) 368-5647
www.uscg.mil/d8/mso/louisville/WebStuff/comdtpubp16761_3b.pdf
Recreational Boating Safety,
U. S. Coast Guard Headquarters:
Commandant (G-OPB),
US Coast Guard,
(202) 267-0984
www.USCGBoating.org
Code of Federal Regulations:
Credit Card: (202) 512-1800, M-F, 8-4
Fax Order: (202) 512-2233 24 hours
Payment by check:
Superintendent of Documents
Attn: New Orders
P. O. Box 371954
Pittsburgh, PA 15250-7954
Customer Service: (202) 512-1803
Free on World Wide Web
Fuel Tanks:
http://www.access.gpo.gov/nara/cfr/waisidx_00/33cfr183_00.html
Marine Sanitation Devices:
http://www.access.gpo.gov/nara/cfr/waisidx_00/33cfr159_00.html
Fuel tanks for USCG Inspected Vessels (<100 GT)
http://www.access.gpo.gov/nara/cfr/waisidx_00/46cfr182_00.html
Food and Drug Administration:
5600 Fishers Lane
Rockville MD 20857-0001
http://www.access.gpo.gov/nara/cfr/waisidx_00/21cfr175_00.html
NSF International
PO Box 130140
789 N. Dixboro Road
Ann Arbor, MI 48113-0140, USA
www.nsf.org
Tel: (734) 769-8010
Toll Free (USA): (800)-NSF-MARK
Fax: 734-769-0109
3069 Solomons Island Road
Edgewater, MD 21037-1416
Tel: (410) 956-1050
Fax: (410) 956-2737
info@abycinc.org
www.abycinc.org
U.S Coast Guard Districts,
Boating Safety Divisions
COMMANDER (opb)
First Coast Guard District
Capt. John Foster Williams Bldg.
408 Atlantic Avenue
Boston, MA 02110-3350
Tel: (617) 223-8480
COMMANDER (opb)
Fifth Coast Guard District
Federal Bldg.
431 Crawford Street
Portsmouth, VA 23704-5004
Tel: (757) 398-6000
COMMANDER (opb)
Seventh Coast Guard District
Brickell Plaza Federal Bldg.
909 SE First Ave.
Miami, FL 33131-3050
Tel: (305) 536-5654
COMMANDER (opb)
Eighth Coast Guard District
Hale Boggs Federal Building
501 Magazine Street
New Orleans, LA 70130-3396
Tel: (504) 589-6298
COMMANDER (opb)
Ninth Coast Guard District
1240 East 9th St
Cleveland, OH 44199-2060
Tel: (216) 902-6001
COMMANDER (opb)
Eleventh Coast Guard District
Coast Guard Island
Alameda, CA 94501-5100
Tel: (510) 437-3324
COMMANDER (opb)
Thirteenth Coast Guard District
Jackson Federal Bldg
915 Second Ave
Seattle, WA 98174-1067
Tel: (206) 220-7237
COMMANDER (opb)
Fourteenth Coast Guard District
Prince Kalanianaole Federal Bldg.
300 Ala Moana Blvd., 9th Floor
Honolulu, HI 96850-4982
Tel: (808) 541-2121
COMMANDER (opb)
Seventeenth Coast Guard District
P.O. Box 25517
Juneau, AK 99802-5517
Tel: (907) 463-2065
Gougeon Brothers Inc.
100 Patterson Ave., PO Box 908
Bay City, MI 48707-0908 U.S.A.
Tel: 989-684-7286
fax: 989-684-1287
URL:
www.gougeon.com
www.westsystem.com
E-mail:
TS@gougeon.com
