Old 10-31-2011, 04:01 AM
metin_mehel metin_mehel is offline
mech.eng.
Rep: 10 Posts: 92
epoxy coating
Hi guys,
I made a boat with okume plywood. The surface up to waterline is coated by fiberglass-epoxy. Remaining surface of the boat was coated only by epoxy.
I will paint the hull with Acrylic primer and paint. Should I sand the hull before applying primer? If so,do yo think the area which is not coated by fiberglass will be sanded as well? I think after sanding, the wood surface will appear.
Thanks A lot
Old 10-31-2011, 04:21 AM
Rep: 670 Posts: 2,457
Yup, you must sand all surfaces to develop a mechanical bond for the paint system.
Normally , after fairing the entire hull , an addition one or two coats of epoxy is applied. This final barrier coat of epoxy is then lightly sanded and painted. Dont sand thru the epoxy coating. If you cut thru the epoxy coating , you have compromised the moisture barrier and must apply another coating of epoxy.
Old 10-31-2011, 04:46 AM
mech.eng.
Rep: 10 Posts: 92
Have you ever coat the wood surface with only epoxy?
Old 11-02-2011, 09:27 PM
Sand crab Sand crab is offline
Rep: 23 Posts: 66
uv
Epoxy has very little UV resistance. If your boat is going to be in and out of the sun like a canoe then it would be OK. For a larger boat permanately in the water the epoxy must be coated over with something. Awlgrip is popular. BOB
Old 11-02-2011, 09:40 PM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
Epoxy only (no glass) is fine. You still need to UV protect the epoxy by either paint of varnish. Glass generally provides for abrasion resistance only in most light craft though it can also contibute structurally in ultralight constructions.
LP
God bless the open minded people of the world. LP
Old 11-03-2011, 06:51 AM
mech.eng.
Rep: 10 Posts: 92
coating
I am building a catamaran. I only coated underwater surfaces. The remaining surfaces are only coated by epoxy once. I think I should coat at least twice. So first I will grind as far as I can see the wood , Then I will coat with epoxy again. But I am confusing little bit. Because coating epoxy layer is so thin and before painting the surface must be grinded. So there will be no epoxy coating on the wood surface. What do you think?
Old 11-03-2011, 07:00 AM
Moisture barrier effectiveness.
http://www.westsystem.com/ss/assets/...eExclusion.pdf
Old 11-03-2011, 08:11 AM
Rep: 23 Posts: 66
Amine blush
One of the reasons for sanding between coats of epoxy is to get rid of the amine blush if your epoxy is susceptible to this. Check with the manufacturer and follow instructions exactly because amine is waxy like and your next coats will not stick and it will be a disaster. Do not grind off your epoxy down to wood. You only need to top coat it with the appropriate paint. One thin coat of epoxy may not give you the water proofing you need. You may need more coats. Sometimes you will need to lightly sand it to get your next top coat material to "bite" into the shiny epoxy surface. This is very common with interior finishes in construction. Once again, if your boat is going to spend alot of time covered or out of the sun then the epoxy will be OK by itself. BOB
Old 11-03-2011, 08:14 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1038 Posts: 1,267
Procedure for coating wood:
-apply epoxy
-let cure
-sand smooth with fine paper (P150, P180). Do not sand though the coating, just top it off to remove the swollen fibers
-apply epoxy
-let cure untill sticky to just hard
-apply epoxy
-let cure
-sand smooth (P180)
-apply epoxy
-sand smooth (P180, perhaps P220 or P240)
-apply paint following the instructions of the paint manufacturer.
This is the procedure we followed at the West System distributor in NL, and this always gave good results.
Old 11-03-2011, 08:15 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
nice one
Originally Posted by michael pierzga View Post
Interesting reading !!
Making beautiful boats is a passion never a chore !
Old 11-03-2011, 10:28 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,840
For best results and a decent thickness barrier without too much sanding, wash what you already have with ammonia and water to remove any amine blush that is there. Sand lightly with 120 to 180 grit sand paper to prep the surface and then put on a good coat of epoxy. Wait until the epoxy is firm but still a bit sticky and apply another coat. This will let you skip sanding between coats. Add another coat when this gets sticky or just let it cure hard (give it a few days) and then you can wash again and give it a final light sanding and then start painting.
Steve Lewis
Lewisboatworks
http://angelfire.com/ego/lewisboatworks
Old 11-03-2011, 12:54 PM
mech.eng.
Rep: 10 Posts: 92
Thank you very much for all these god informations. One another question:
Think that you build a sailing yatch 12m. Should we coat the exteriour of the hull with frp fabric and epoxy? Or just epoxy can be enough?
Old 11-03-2011, 01:27 PM
Depends. Fiberglass cloth set in epoxy might be a structural component.
If your design does not call for fabric , then obviously you dont need it.
The great benefit of cloth set in epoxy is chafe resistance and a moisture barrier.
When you bond light 6oz fabric over plywood , you automatically achieve the necessary film thickness of epoxy to form a moisture barrier when you fill the weave of the cloth fabric .
As you as presently finding out its very easy to SAND THRU an epoxy only finish on wood.
Cloth set in epoxy avoids this moisture barrier compromise by giving you a visual key when sanding and fairing.
Old 11-03-2011, 01:28 PM
Rep: 23 Posts: 66
12m=fabric and epoxy
epoxy,epoxy, opps flooring epoxy aboyd Materials 5 09-12-2009 02:56 PM
epoxy coating a wooden boat mickjur Wooden Boat Building and Restoration 34 07-04-2009 06:27 PM
deck coating skiffish Materials 35 01-24-2009 10:35 PM
Deck coating to use over epoxy and fiberglass sbklf Materials 3 07-25-2007 08:11 PM
barrier coating epoxy fastests10 Boatbuilding 0 08-12-2002 10:01 PM
