Old 11-18-2002, 09:09 PM
fast_c_class fast_c_class is offline
engine overall dimensions
does anyone know of the dimensions for a 40-55 horse johnson - evinrude 2 cyl. outboard. i currently have a 1960 40 horse and want to upgrade but it looks like the newer motor ( late 70's to current omc design) is longer front to back in the powerhead.
i looked on bombardier s website but no luck, i was hoping someone has a old brochure, manual, or an actual motor they could grab the measurements from.
thanks. ill attach a pic of the boat its going on
thanks
Old 02-06-2003, 11:05 PM
Rep: 1397 Posts: 7,215
The new motors fit fine. All outboards, at least for the past fifty years or so, are designed to fit a standard motor well. The mounting holes may be different though. Specially if you are changing makes.
How to make snowmobile engine work in a small 11 ft. runabout? rvBilly Propulsion 8 09-02-2005 10:49 PM
Propeller sizing and engine loading E4ODnut Props 3 12-29-2004 05:50 PM
Engine Torque Curves Pat B Propulsion 22 10-06-2004 05:36 PM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 04:06 AM
