Old 12-29-2011, 05:49 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1038 Posts: 1,267
40C is a bit low for postcuring, as the Tg will raise to some 55-60 degrees only. For optimum properties go a bit higher. Easy to be done in your area, you already start at 40. Sometimes we are happy to reach 40 WITH heater. You will probably be able to reach 60 or so. Well done!
Old 12-29-2011, 05:50 AM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
Yeah, I know. It's great. The one big advantage of this heat, other than working over the winter.
A one day heater rental (which may not be expensive because only crazy people need a heater at 41C!) will do the trick.
I just have to be careful because all of my various epoxies have different post curing requirements. I don't want to over cook any of them.
"You can't solve all of life's problems with epoxy" - My Wife
glass print through ! tunnels Fiberglass and Composite Boat Building 16 02-06-2011 11:23 AM
RIB outside print through hyboats Fiberglass and Composite Boat Building 13 08-05-2010 10:13 PM
Print through Carbonman Fiberglass and Composite Boat Building 0 08-08-2009 10:18 PM
Eliminating High Speed Porpoising Jango Inboards 2 06-08-2008 07:13 PM
Eliminating Running Backstays From A Design LFH Fan Boat Design 5 02-15-2008 06:37 PM
