  #121
Old 12-02-2012, 04:59 PM
masalai masalai is offline
masalai
Rep: 1882 Posts: 6,847
Originally Posted by michael pierzga View Post
Flush hatches are high maintenance. Stand proud hatches give a good toe hold when working in deck and are easier to keep watertight. - - - Hatch frame waterways on flush hatches e prone to clogging. Use many drains and make it easy to maintain these drains.
My hatch waterways are a persistent problem - always clogging and where does the 'dust' come from? - just days after a good 'gurneying' with high pressure water-blast
Try to be helpful...
Remember that there are at least two sides for every story...
  #122
Old 12-09-2012, 01:53 AM
groper groper is offline
Rep: 693 Posts: 2,087
I infused another forum members rudder today, i made a short video of it shown below...
I decided to infuse it for several reasons, the first being it was easier to wrap all the edges in glass. Using the vacuum bag, it pulls tight around all the edges and it gets a solid wrap on all the edges which would be difficult to do via a hand laminating. Another reason was it allowed the whole laminate to be completed in one shot rather than 1 side at a time and waiting to cure between... And yet another reason is its less work, less time to infuse it - this whole setup took about 1 hour including cutting up the materials getting the bag sealed and leak checking etc... the laminate was 4 layers of 820gsm triax on both sides, this would have taken quite some time to lay by hand including wrapping the edges etc...
Heres how it went;
And heres a shot about 10 mins later after the resin line has been clamped off and the rudder is almost 100% filled.
  #123
Old 12-09-2012, 02:51 AM
masalai
Bloody neat work, thanks for the view...
Some kids? lit a fire on the banks of the river - About 500M SE of the house where I am staying, Next door is a volunteer bush-fireman, ,hooning, around in self importance, whereas I had been around for a quiet look and assessed the situation was of modest risk to us and adjacent neighbours, else I would have phoned and reported the incident otherwise...
  #124
Old 12-09-2012, 03:58 AM
Rep: 1180 Posts: 4,865
With rudders Im constantly picking up junk at the rudder to hull interface. Any defensive strategy to keep junk from getting caught in this area is worthwhile. Mini skeg, kelp cutter type apendage. The stern, over the rudder and prop, is a very good place for an underwater light and perspex viewing window. An aft facing depth sounder is also a winner.
  #125
Old 12-09-2012, 05:48 AM
masalai
Hi again Michael,
I have the mini-keels as well as the sail-drive legs before flotsam comes near the rudders... No problems there so far...
Thanks...
  #126
Old 12-09-2012, 06:07 AM
Much depends on the nature of the water you sail in. Kelp, plastic, discarded fishing gear........if its clean tropic water you're pretty safe.
If you make it a habit to break your anchor out, then maneuver in reverse while retrieving your anchor and chain , you can avoid dragging junk like discarded fishing nets, plastic tarps and cables under your boat.
I pick up all sorts of junk every year. Ghost fish nets picked up with the anchor are treacherous.
  #127
Old 12-09-2012, 11:32 AM
portsmouthmarin portsmouthmarin is offline
Previous Member
Kick up rudders are the answer. Just lift it up and off slides the junk. Works on multihulls, anyway.
  #128
Old 12-11-2012, 01:59 AM
so heres what the rudder looks like after its cured and the infusion consumables are stripped away...
Then the flash is cut away and the edges are trimmed up with a grinder, this is what is looks like 5 mins later...
Then its time to start the fairing process, so first coat of low density epoxy bog is applied with a 4mm notched adhesive trowel... this is what it looks like 20 mins later...
Ill have to wait until tomorrow before proceeding, let the bog cure and then get busy with the longboard...
  #129
Old 12-11-2012, 02:40 AM
Serrated bog is a nice way to fair. Just did a keel panel, serrated bog, board sand , second bog coat peel plied and wiped with a plexi plank . Came out 95 percent.
  #130
Old 12-11-2012, 03:00 AM
masalai
What can I say but WOW
  #131
Old 12-27-2012, 01:56 AM
fore deck is on the boat... was made in 2 halves then offered up onto the already standing frames...
Heres a pic of the foam core, prepped with high density inserts for the stanchions and cleats, and a recess for a drop in escape hatch gutter mold.
And heres a pic of both sides up and in position on the boat, the brown colour is the polyester peel ply im using at the moment... and look at all that damn imprint from the resin lines... i need to find a better material as opposed to spiral wrap for this purpose to eliminate it, i know its out there somewhere...
  #132
Old 12-27-2012, 06:59 AM
jorgepease jorgepease is offline
Rep: 71 Posts: 806
that is looking great ... is there a reason you infused down instead of up on the rudder?
  #133
Old 12-27-2012, 07:49 AM
yep just 1 reason, it was easier to drape everything over the rudder this way. To go up hill and still keep my flow media break at the end, would have required staples or similar to hold it where it needed it. In addition, i simply wanted to see how it would go and if it caused any problems - which it didnt, so id feel more confident about going downhill if i ever need to in the future...
  #134
Old 12-27-2012, 08:26 AM
Rep: 71 Posts: 806
Ok, was just thinking I'd like to do my stringers that way, thanks!
  #135
Old 01-25-2013, 06:23 PM
strong winds has damaged my plastic boat shed, so i can take a pic from a different angle... i think ill wrap things up until the cyclone season has passed...
Efficient Displacement Hull ChrissyT Boat Design 5 02-20-2011
12:14 PM
Kayak an efficient displacement stern shape? pkoken Boat Design 9 01-13-2008
04:11 PM
Efficient Displacement Hulls Karsten Powerboats 19 06-07-2006
09:25 AM
Who can build me a powercat in Asia Frosty Boatbuilding 43 09-13-2005
01:23 AM
Small Displacement powercat Baycat Boat Design 11 06-28-2004
09:39 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
