Old 04-13-2011, 12:28 PM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
Dying Off Laminates at Transom?
I'm curious about how to die off a cored laminate at the transom.
Currently, I just have my transoms all over the place - they are runwild with no "bulkhead" installed back there, so it's easy to get in and out of the hull.
My hull lamination schedule is as follows:
34oz/1150g triax
1" (25mm) of 6lb/100kg foam
34oz/1150g triax
That's what I have at the end of the boat at the transom, just run wild and untrimmed (they will need trimming for looks later).
So how do I die off this laminate at the transom?
Also, what about slight peels or never bonds at the edges? I have one or two tiny spots where the laminate is not quite completely on the foam. These spots are not even 1cm (1/2") in from the edge of the laminate and are very small. Do I need to worry about those spots, or will the layers of biaxial to be place on them, joining the keel and hull halves take care of that?
"You can't solve all of life's problems with epoxy" - My Wife
Old 04-13-2011, 06:30 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,355
How numerous are those 1/2" spots? How close together are they?
Hoyt
Old 04-13-2011, 06:34 PM
There are possibly 4 of them. They average 6" in length. They are fairly evenly distributed along the edge of 45' and not concentrated in any one place.
Old 04-13-2011, 06:40 PM
hoytedow's Avatar
Resistor
Can you inject them with epoxy to fill them and thereby avoid a "crunchy" zone?
Hoyt
Old 04-13-2011, 06:59 PM
Yes, very easily. They're on the edge of the laminate. I could even take a stick and shove bog into them they are so easy to access. I could stuff them with dimes or pennies.
What happened is a little bit of the edge of the glass peeled back off the foam during (or just after) lamination. I didn't catch it at the time.
The area of the boat this happened on is where the two half-hulls come together at the keel. So, this is inside the keel, which will have many more layers of "things" including structural bog and biaxial over it.
My main worry is that one of these little spots could somehow start a larger delamination years down the road.
Not sure if I'm being too anal.
Old 04-13-2011, 07:18 PM
hoytedow's Avatar
Resistor
You know I am not a professional, but I think if it is solidly filled, reducing the chance of expansion contraction or other such action, the chance of delamination will be greatly reduced. A bubble, on the other hand, could lead to nightmares. We need a professional opinion here. Just my 2 cents is not enough.
Hoyt
Old 04-13-2011, 07:21 PM
bntii's Avatar
bntii bntii is online now
Rep: 1073 Posts: 704
I always grind out voids.
Old 04-13-2011, 07:23 PM
hoytedow's Avatar
Resistor
That sounds good to me, followed by leveling the ground area before joining hull halves.
Hoyt
Old 04-13-2011, 07:32 PM
Ok, then what do you do?
How do you glass the void properly after grinding it out?
Old 04-13-2011, 07:36 PM
hoytedow's Avatar
Resistor
I build it back up with cloth and epoxy. having feathered the edge around the void.
Hoyt
Old 04-13-2011, 07:50 PM
I've never understood that.
I have a single layer of 34oz (1150g) triaxial over the foam. How do I "feather" this?
Old 04-13-2011, 07:56 PM
hoytedow's Avatar
Resistor
Bevel the edge by sanding, then lay in some more glass and sand that new glass level, like in the amended sketch.
Hoyt
Old 04-13-2011, 07:57 PM
hoytedow's Avatar
Resistor
It will then be covered with more glass. Yes?
Hoyt
Old 04-13-2011, 08:16 PM
Yeah, but it won't be homogeneous.
The patch will differ (structurally) from the original laminate because you'll have a double stack of +/- 45 cloth and no 0 deg cloth in the bevel because it will be sanded away during final finishing. (assuming 0 is up and the 45's are against the foam in the original laminate)
The 0 deg fiber is very important. Thats what makes the boat strong in the most important direction of stress (longitudinally).
You won't be left with the same type of laminate as the surrounding areas.
Triaxial looks like this:
Old 04-14-2011, 04:58 AM
hoytedow's Avatar
Resistor
In that case, if the grind out would be that significant structurally, then inject the voids to remove the voids and proceed as planned. That way you will not have compromised the original layer. However you do it, the air bubbles should be eliminated.
Hoyt
Fish & Birds Dying by the Millions! WickedGood Open Discussion: All Things Boats & Boating 9 01-07-2011 09:47 AM
OMC 350 dying JerryIkemire Gas Engines 5 07-09-2010 07:52 AM
laminates and adhesives grokcam Materials 5 12-29-2009 04:26 PM
Accepted thickesses of E glass laminates catsketcher Boat Design 1 04-25-2008 07:43 AM
fiber content in GRP laminates ??? mistral Materials 5 09-22-2004 11:51 PM
