| Douglas Fir Hi all! Thanks for your invaluable help. Originally I was planning on using Southern Yellow Pine for my frames on my 20' power dory. Now I am reconsidering and thinking about Douglas Fir for frames. It would help reduce the weight. However, I don't know about the strength factor. Any thoughts would be appreciated. The plywood skin is going to be Hydrotek ( a marine grade Meranti plywood) which is ideal for boats but is 20% heavier than Okuome so I would like to compensate for that added weight with lighter frames if possible. |
| Honestly, I wouldn't be all that worried about the weight gain with Meranti over Okoume. A 20' dory would be hard pressed to use more then 8 sheets of plywood. This means your Meranti hull will be about 40 pounds heavier then a Okoume hull. Hell, that's just a cooler full of beer or a battery for running a boom box. Douglas fur is significantly weaker then southern yellow, too. |
| stick with the pine. if you want a weight savings in the framing, switch to a hardwood like white oak, you can go thinner for the same strength, and save yourself some weight there. as par said, don't worry about the hull. |
| Fir Douglas-Fir | waxer | Materials | 1 | 06-22-2008 09:39 PM |
| Kiln Dried vs Air dried Douglas Fir | Thomas Wick | Boat Design | 6 | 02-11-2008 07:34 PM |
| Douglas Fir | drs3317 | Wooden Boat Building and Restoration | 17 | 06-10-2006 07:50 PM |
| Plywood or Douglas Fir supports? | drs3317 | Wooden Boat Building and Restoration | 10 | 12-14-2005 08:20 PM |
| Douglas Fir Mast. CPES - use in restore/refinish? | Robert Miller | Wooden Boat Building and Restoration | 2 | 09-13-2005 01:38 AM |
