Old 08-15-2008, 08:22 PM
Breakwater Breakwater is offline
Rep: 10 Posts: 12
Discussion - Vacuumed Boat Mold from finished Plug
Hi All,
I have a few mold creating questions specific to my application. Sorry, I know the topic has been covered, but I wasn't able to find much info searching.
My plug is finished, and I want to make a mold of it now. (see attached picture of my plug.) I will be vacuum bagging the mold, and I'm curious how to make a gunwale flange, so that when a hull is formed in the mold, it will have a clear crease where it should be trimmed.
if I were to lay a sheet of thin ply across the gunwales I would create a flange on each side, but a giant cavity in the bilge (or back-side of the ply) for the vacuum to crush.
So, do I attach a 2-inch wide strip running the length of the boat, and use that as a flange? or are there better ways. Any help is appreciated since I am totally new to bagging.
Also:
How much time should the unit is left under vacuum pressure? (I usually allow epoxy 2-3 days to cure before working with it again.
How much resin should be wetted on the composite before the vacuum is turned on? (So that it fully impregnates the composite, but doesn’t have an exuberant amount of excess bleeding through.)
How many lbs Mercury or PSI should I be running inside the bag?
THANKS!!!!!!
Old 08-16-2008, 01:02 AM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
attach the pic and we might be able to help
Old 08-16-2008, 02:49 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 501 Posts: 939
Breakwater, you have to use your contact molding surface as one side of the vac bag "envelope", dont pull down the vac on an air filled void or you will crush/deform it. Regards from Jeff.
Old 08-19-2008, 06:20 PM
Rep: 10 Posts: 12
Sorry,
I didn't realize I made 2 threads.
I appreciate the help, but could you please follow it here:
Thanks
Building a plug & mold Itchy Fiberglass and Composite Boat Building 17 03-08-2007 09:24 AM
Plug and mold construction sandman1984 Boatbuilding 3 12-23-2005 08:08 PM
Help Wanted Design, Plug, Mold and Builder Cpt Albert Fiberglass and Composite Boat Building 7 07-01-2004 06:45 PM
Help Wanted Design, Plug, Mold and Builder Cpt Albert Boat Design 0 06-28-2004 09:55 AM
plug/mold fabrication cfox Boat Design 8 06-23-2004 11:55 AM
