#31
| make a jig for that beam saw and cut it from both sides. Ive done lots of odd ball cutting and if you want accurate joinery you gotta use a jig if your cutting anything irregular in shape. And yes you can work wonders with a chain saw if your well enough practiced but an amateur with one is damn dangerous specially on a plunge cut like what your describing ![]() it can be a simple plywood form like a box or something that slips down over the offending piece. Lay it out on the jig and do a practice piece, once you've got it down then try it out on that million dollar looking dagger board. Best of luck B
__________________ I am skeptical of the deniers diatribe |
#32
| I would screw a metal guide to the back side such as some 3/4" by 1.5" tubing or what ever else you have handy put a little lube on the tube and if your careful the sawsall blade will follow the tube and your cut will be square remove the screws and fill the holes. I like the picture I tried to zoom in to see the dagger board. Dave T |
#33
| If only I *were* an amateur with a chainsaw... I'd probably be a more pleasant guy! ![]()
__________________ "You can't solve all of life's problems with epoxy" - My Wife |
#34
| ahahahaha I've just seen a lot of accidents. And my condolences for the experience. Its kinda a curse knowing how to build a "logy", once your labeled competent with a chain saw, if your not careful, its all you'll ever do. Back in the day I'd get calls about once a week, someone building something with log accents. Anyway do the jig and the beam saw. A sawsall will never give you a very nice cut, its more of an eraser than anything else. cheers B
#35
![]() I don't know where this thread came from again (it's old), but I ended up just using a hole saw on the 4 corners. I went far enough through that the pilot bit popped out the back. This gave me a true center to go at it from the other side with the hole saw again. Those round cuts then fell out... Then I used a circular saw to cut part way through the glass/foam on each side, connecting the 4 corners (which were already cut out by the 4 hole saw cuts). From there, I used a hand saw to cut the remaining foam in the center of the board's core... tidying the whole thing up with a belt sander and a bit of hand sanding in the hard to reach spots. I guess a jig may have been faster, but those boards are now done.
#36
| why is it that most of the time nudist are exactly the people you don't want to see with there cloths off. ![]() ![]() ![]()
#37
| Best tool for cutting a laminate? | CatBuilder | Fiberglass and Composite Boat Building | 23 | 02-23-2012 06:32 PM |
| How difficult to convert this engine to variable speed? | Homefront | Diesel Engines | 49 | 08-21-2010 01:14 PM |
| FLUENT - How difficult is to use it? | Panos_na | Software | 2 | 09-15-2009 12:30 PM |
| Recommend a good cutting tool for building boat | denniswang | Open Discussion: All Things Boats & Boating | 9 | 02-26-2006 10:33 PM |
| Difficult To Find Book | ADRIAN77 | Propulsion | 0 | 11-10-2004 12:49 PM |
