| I had some negative response when I said "dont mix up polyester and epoxy" and it seems like that epoxy can be used on "everything" but never use polyester on epoxy!. However, scrub the surface down a bit to get good bounding! Good luck! |
| Yep, epoxy on polyester, but not polyester on epoxy. Kinda like you can prick your finger, but ...
__________________ Wherever you go, there you are... |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 04:48 PM |
| Jet Drive | Jet Drives | 15 | 12-18-2006 09:51 AM | |
| Stepped Hulls | Ryon Macey | Powerboats | 53 | 08-01-2004 10:44 AM |
| Crack in joint of two piece hull... | ErikG | Sailboats | 5 | 04-07-2004 11:23 PM |
| connecting deck to hull | Sgray | Boatbuilding | 10 | 01-22-2003 05:03 PM |
