| Curved Transom Bevel I'm building a Glen-L utility and have drawn out the Transom. The plans call for a 13.5 degree angle on the bottom and 7 degrees on the sides. All edges are curved. How do people cut this bevel? After doing some searching, I see a lot of people saying they use a table saw, but with all curved edges I don't see how that would work. - Sabre Saw? (That seems like it would be inaccurate and wavy) - Cut edges square with bandsaw or sabre saw, then plane off the angle during fairing? Thanks! |
| It can easily be done with a jig saw and cut outside the line 1/8" or 1/4" then use a sander to remove excess to the line keeping the angle. I shoud say using a quality jig saw not a $19.99 cheapo. If you are just a little off, quality epoxy will fill and do the rest for you. Just sand off any high spots. |
| Thanks for the reply. So you are saying to cut the edge straight up and down with a jig saw, then bevel with the sander? Or cut on an angle with the jig saw, and just clean up with the sander? |
| You can cut curves with a flat blade like on a skilsaw or tablesaw if they are not too small of a radius. You can cut freehand on a tablesaw but it is dangerous. |
| Use a circular saw to make a rough cut and then finish with a low angle block plane.
__________________ Gonzo |
| You can use various saws, I prefer a jig. Cut on the angle then use sander. |
| Curved surface on plug? | Bill Brasky | Fiberglass and Composite Boat Building | 21 | 01-22-2011 06:55 PM |
| Understanding Curved Boards(in the A Class) | Doug Lord | Multihulls | 0 | 11-05-2010 08:00 AM |
| curved decking | losttool | Wooden Boat Building and Restoration | 15 | 07-27-2008 11:50 PM |
| Cutting the bevel on coreing material. How? | jim lee | Fiberglass and Composite Boat Building | 1 | 12-16-2007 10:39 AM |
| two right angle bevel | toussy | Inboards | 1 | 04-07-2007 11:31 AM |
