Old 08-20-2005, 04:51 PM
terabika terabika is offline
Rep: 10 Posts: 46
crazy idea???
Hello, I have a 31ft westerly longbow. She was sunk and now is up. I need a longer boat. I do not have the money so I propose to cut shiloh in two at the fullest part under the water line of the hull. at this point the water flows parrallel to the waterline. I then hope to spread her for and aft sections some ten feet and fill this space in with mutible layers of 1/4 inch plywood epoxied to eachother ( I use this because it is easier to curve thinner wood. there will be no attemptat compound curvature. SO, in profile she will have a ten foot flat section. I will glass over this with some number (I am thinking thre now)of layers of epoxy inside and out. I will use common exteior grade playwood and layer it up to a thickness of 1.5 inches to be sure it is strong enough. This should more than compensate for the voids in wood. Exterior 1/4 inch is 10 bucks a sheat, marine is 40, thats why! 1 foot of overlap inside and a scarf on the outside will ensurebonding. Any thoughts would be appreciated. Yes, it is wayyyy cheaper then buying a 41ft boat and it should be faster as its hull length to beam ratio will be thin and it will still be wayyy lighter than comparable boats. She has a 4k lb keel I will reinstall and make lower for a draft of 6 ft or so...toying with idea of retractable. thanks!
Old 08-26-2005, 06:03 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
Get an expert for this one - it can be done in steel but they always look dodgy as to a tupperware job, guesss it's sunk once so another sinking won't hurt her?!
Old 08-27-2005, 11:33 AM
Rep: 10 Posts: 46
no bucks
dont have bucks for an expert! but, 3 ft is not that much and as long as joint is strong wnough....may not be the perfectly balanced boat but May sailing on craft with non stock sails and such leads me to believe this is not as important as some make it out to be....they have to keep themselves important right? polinesions seemed to do Ok...
Old 09-26-2005, 08:14 AM
Bergalia's Avatar
Bergalia Bergalia is offline
Rep: 254 Posts: 2,517
Crazy idea ???
If my memory serves me aright they cut the R101 in half to add a further section... Look what happened to her.
Bad idea.
Home made trim. Original idea? stratus5 Propulsion 0 10-02-2005 06:24 PM
crazy idea??? terabika Boat Design 14 08-24-2005 04:57 PM
Crazy Canadian Canoe Craft KaiCarno Boat Design 12 03-17-2005 04:00 AM
Just an idea gulfcoast crabb Boatbuilding 1 12-31-2004 05:03 AM
A Thick Glass Over Ply Hull? NEILIUM Wooden Boat Building and Restoration 12 10-09-2004 08:03 PM
