Old 10-05-2009, 07:04 PM
wardd wardd is offline
Rep: 443 Posts: 925
cost ratio ply v alu
for a boat 30 feet in length can anyone give me a cost ratio between aluminum and plywood when epoxy, glass and paint are figured in
Old 10-05-2009, 07:33 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Are you looking for the cheapest or the best material ?
Regards
Fanie
Water ! Just gimme water !
Old 10-05-2009, 07:36 PM
Rep: 443 Posts: 925
right now im weighing all options, time, cost and ease
Old 10-05-2009, 07:42 PM
Fanie's Avatar
Fanie
Personally - and this in only my opinion - I don't like alu very much, not for a boat. I think it will be noisy and tin like and not as strong as glass. Glass and especially wood has a very warm and personal feel to it. I like glass, it would be my first choice.
Almost forgot to say - imo it's not what comes out the cheapest, it what works the best within reason.
Masalai is currently building a cat, have a look here
My little piece of peace
Regards
Fanie
Old 10-05-2009, 09:47 PM
Rep: 2891 Posts: 8,798
At 30' aluminum isn't really competitive as a building material yet, so plywood is a cheaper alternative, but not the only one. Plywood is getting out of it's range of competitiveness at 30' and 'glass may be a better choice. 30' in steel is still on the small side to make it viable, but one off 'glass is a consideration.
In the end, the choice of hull material has a fairly small impact on the total cost of the project. Aluminum, being such an expensive material, needs to use it's weight savings advantage to offset it's initial cost, to make it viable. Steel is the other way around and need the displacement to be fairly substantial to warrant it's strength and low cost advantages in larger sizes.
The hull material can be fairly subjective at 30'. An expensive aluminum job, but light, maybe a pretty wood veneer over plywood hull, finished bright, possibly a foam cored 'glass speedster or a bullet proof solid 'glass hull, a cold molded or strip plank round bilge or best yet for looks and charm a glued lapstrake.
It's a crap shoot, so pull out a coin and start flipping.
Old 10-05-2009, 10:13 PM
Rep: 443 Posts: 925
its a sharpie design so its all slab sided and flat bottomed no forming or complex layout needed
im comfortable working with metal and thought construction would go faster than having all the labor wood seems to require
my thought was flat panels and extruded shapes for framing and stringers
with interior partitions and interior decking of ply
im a strictly form follows function guy.
in fact i only plan on 2 cruising comfortably with more than 2 strictly a day sail
my criteria is ease of getting in the water, ease of maintenance, cheap to sail safe to sail, easy to sail,
its a proven design in ply so im sticking closely to weights and balances in the final build
and fiber glass sends me climbing the walls
ply tp alu wardd Boat Design 4 10-09-2009 05:10 PM
hardening alu sigurd Materials 10 10-05-2009 05:13 PM
1:78 ratio vs. 1.47:1 ratio ... which to choose? ezfriday Propulsion 18 02-18-2006 09:21 PM
Anodised Alu AlMgSi0,5 Danielsan Materials 1 08-25-2005 06:48 PM
absolute beginner ply/epoxy or ply/glass wannabe Materials 9 08-13-2004 06:01 AM
