| corrosion, bolts etc hi all. i'll be wanting to attach 15 ft of stainless steel traveller track to an aluminium truss beam. what would different people here do? thanks, mal.
__________________ "No television! The living would envy the dead." |
| be careful of dissimilar metal contact |
| would you put a strip of wood / epoxy fiberglass between them?
| when i worked on aircraft we used a tape to isolate them and a zink chromate paint the fasteners were dipped in. otherwise corrosion would develop that was many years ago, there may be better ways now its something youll have to look into some of the boat builders here could be a better source of info on current methods |
| ?! from http://www.scorpiosail.com/web/mast_2.html ![]() i don't ever want to play that game can you install a sacrificial anode on the mast? what about using aluminium rivets? surely this is better than coupling more dissimilar electrolytic metals? plastic washers & sleeves plastic bolts Nylon Bolts keep it dry epoxy with ceramic powder ie fumed silica to decrease the osmotic diffusion rate to the lowest you can plastic bolt manufacturers http://www.craftechind.com/materials.php Yield strength of reinforced plastic is comparable to aluminum
| An aluminum rivet is of a different alloy and thus dissimilar. |
| Make or have an intermediate part made from epoxy and glass or carbon fiber. Two half circles clamping around the mast would avoid all direct contact between dissimilar metals. |
| woahhhh....looks like it could be cheaper (inferior) 304 SS...which doesnt help! |
| Sensible anti-corrosion measures:
Jimbo |
| Formica laminate will be cheap and effective as an isolation material. Low compression and easily cut, free from kitchen counter fab shop scrap pile. |
Some have no place on a boat just as some are not at all suitable for food contact. Jimbo |
| lay some fiberglass tape down on a flat surface and make your own isolator |
| To be honest, I'd forget it. Get back to basics. The basic issue is that mixing SS & ally ain't a runner so why not purchase or fabricate the track in ally. End of problem. |
| A very good product for this application is DURALAC. I use this for all fastenings an alloy tracks when fitting out and maintaining composite race yachts. |
| Concrete bilge corrosion | RCardozo | Metal Boat Building | 3 | 04-09-2007 09:27 PM |
| Fastener Corrosion | Phosphor | Sailboats | 6 | 04-25-2006 04:30 PM |
| SS and Pit Corrosion | lewisboats | Wooden Boat Building and Restoration | 10 | 03-31-2006 07:12 PM |
| Corrosion between Al and carbon | grob | Materials | 11 | 02-18-2005 12:39 PM |
| Carbon and corrosion | Ssharpsjc | Materials | 5 | 07-08-2003 09:24 AM |
