Old 09-28-2008, 11:28 PM
Willallison's Avatar
Rep: 2366 Posts: 3,560
Cored panel joinery
Not the most riveting of subjects I'll grant you....
Just interested to hear from other's as to how you treat the joints in cored panel joinery. Manufactuers tend to suggest that all joints need to be taped. Builders that I've spoken to use a variety of approaches, ranging from simply gluing them together, to coring one or both panels prior to gluing, to making a sort of 'biscuit' joint, to the afforementioned taped joint.
Obviously, taping would be superior in terms of strength, but it is regarded by many as overkill and requires a great deal of fairing.
Thoughts...?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 09-29-2008, 12:33 AM
Yacht Designer/Builder
Rep: 3465 Posts: 11,649
On a couple of occasions I've made a "reversed" flange fillet, inside the joined panels to hide the fillet.
These instances were hardwood faced cored panels and the owner didn't want to see fillets, even if I taped them off nicely or covered them with a bit of trim. The sectional view of the joint would look like two butted fillets against the centerline of the joined panel. The edges of the panels were taped and remained clean.
I doubt That I'd trust them for bulkhead or other heavy structural load situations, but for furniture it worked.
Old 09-29-2008, 03:16 AM
Thanks Paul. In this instance, the panels are all FRP skin / Foam core, which will be painted and with no fiddles or anything: somewhat like the simplified pic below.
The manufacturer recommends this approach, but as I said before, would require a great deal of fairing.....
Will
www.imaginocean.net
Old 09-29-2008, 05:54 PM
Okay, I'll bite, what picture . . .
Old 09-29-2008, 07:07 PM
Oops...
Will
www.imaginocean.net
Old 09-30-2008, 05:37 PM
If it's a structural panel, then you'll have to attach tabbing to the panel skin. I'd do it a little differently (solid laminate corners), but you'll still have considerable fairing.
If it's not a loaded panel, then I'd under cut the core, bond to the back side of the skin with minimal tabbing, trying to be as neat as possible, then smash them together until cured. Maybe sacrifice one side for a good tabbing job, butt joining the more difficult to fair side, in a bed of thickened goo.
joinery drawings svetlanica Education 3 11-22-2007 07:45 AM
Asian Rendering / AutoCAD / Joinery Design Teams Available Billy Baycroft Services & Employment 0 08-20-2007 10:45 PM
Cored hulls and stringers??? Alan Power Fiberglass and Composite Boat Building 1 03-22-2005 11:02 PM
cored hulls aguest Boatbuilding 10 12-09-2003 12:15 AM
Sandwich Cored Structures GordMay Fiberglass and Composite Boat Building 5 11-07-2003 07:44 AM
