| concrete in keel Hi all, I've purchased a steel ketch which i plan to strip completely and make a new interior, the long keel is filled with scrap iron, steel punchings and concrete, I'm thinking of chiseling out the concrete & scrap iron and replace that with lead and a layer of poured in expoxy. Anyone has any thoughts about such a project, should i weigh every bit of concrete and iron and put in the same weight of lead? with kind regards, Tom |
| kryptonite would be denser |
| unfortunately i'm using my limited supply of cryptonite for other purposes ![]() |
| Let the Mythbusters remove the concrete. ![]() The serious part: If the concrete is dry and doing its job, why remove it? Lurvio
__________________ Hopefully creating something useful, since 1983. |
| Ditto Lurvio's thought: why remove it? Especially if you are just putting the same amount of weight back. I have seen concrete used on older designs, it is inexpensive but not as dense as metal, especially lead, so the keel has to be larger. It sounds like the concrete is there to hold the scrap metal in place. If you wanted to add or change the amount of ballast, that would be a reason to change it. IF you are worried about it corroding or chipping out, clean it up in place and seal it with epoxy. |
| I think you already have another thread on the same subject. The structural stresses will increase with a concentrated ballast further below. It may end up in hull and rig damage. Also, it will make the boat more lively.
__________________ Gonzo |
| glassfiber over concrete | tropicalbuilder | Fiberglass and Composite Boat Building | 2 | 06-14-2010 04:44 PM |
| concrete | evantica | Stability | 26 | 05-21-2010 12:45 PM |
| Concrete submarine | waterchopper | Boat Design | 852 | 12-10-2009 03:55 PM |
| Concrete Canoe! (Help) | Luciano | Boat Design | 13 | 06-13-2009 04:44 PM |
| Making a keel bulb mold from concrete | Sam III | Boatbuilding | 3 | 03-01-2009 12:49 PM |
