Old 09-26-2005, 04:22 PM
westsail42 westsail42 is offline
Rep: 10 Posts: 44
Composite Replacements for Plywood
Has anyone tried this stuff?
http://www.coosacomposites.com/
PU foam sandwiched with roving.
I am getting ready to tab in floor timbers and bulkheads in my (now bare) WestSail 42.
I was originally planning on doing fiberglass over closed cell PVC foam.
But, tabbing this stuff seems like it would save a lot of time. Though it would be more expensive. (I am looking to save time here).
My local supplier has it at $188 per 4x8 sheet, 3/4" thick, 20 lbs/cu ft density.
They claim it can be sanded, painted, laminated. Basically anything you would normally do with plywood.
Old 09-26-2005, 07:30 PM
Rep: 494 Posts: 3,842
I've used for decks and cabin soles instead of plywood. It is amazingly stiff and works easily with saws and drills. The dust is as ithcy as grinding fiberglass.
Old 11-06-2005, 10:12 PM
drs3317 drs3317 is offline
Rep: 10 Posts: 47
Gonzo,
I too am planing a project with it and had some questions. I was thinking of using the 3/4" Bluewater.
Which grade did you use and what method of bonding did you use? Did it appear to asorb moisture?
Old 11-07-2005, 08:34 AM
I used it as a core with polyester resin. It doesn't appear to absorb water. However, if the laminate is done correctly, there shouldn't be any water intrusion.
Composite Design Engineer seeking employment benadeline Services & Employment 0 07-24-2005 02:38 PM
Composite ocean row boat advice OceanRowSolo Fiberglass and Composite Boat Building 7 01-26-2005 09:53 AM
Is this progress in composite construction? Mark Peiffer Fiberglass and Composite Boat Building 16 01-13-2005 12:35 PM
Volvo Composite Stern Drive Jeff Powerboats 5 08-31-2003 04:48 PM
Composite masts David Avalos Boatbuilding 0 03-04-2002 04:19 PM
