Old 06-18-2007, 03:45 PM
Pipsta Pipsta is offline
Rep: 10 Posts: 4
Collapsible raft design, Help!
i was floting the colorado river the other day in 1.50$ walmart pool toys when i desided to build a raft, i ahve a small pickup and i wanted to beable to haul it around so i stayed up last night drawing up some designs, they are mostly baised off of
http://www.captainfletch.com/project...barrel_top.asp
But wit some mods, if u guys could help me with some constructive criticism that would be great heres the pic: (this is not to scale)
steel cables go around the 55 gallon drums and the top half bolts onto the bottom half uhhh.. and the same bolts used to bolt down the 2 halfs also serv to tightne the cables around the drums aslo the middle section that is lower than the deck will stableize the durms. (if that made any sence)
Old 06-21-2007, 04:09 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
So far, I see naughty miters. Use butt joints or lap joints on the corners!
Cable idea is fine, though more expensive and more prone to corrosion than 1/8"x 1" bar stock, which could be bent around easily and have a hole at one end and a coupling nut at the other.
Also, see if you can either add barrels or shorten the raft---- weld the barrels together at the lip, make a long pontoon, easier to motivate that raft.
Alan
Old 06-21-2007, 05:53 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
I like Alan's idea about welding the barrels together. Just make sure they did not contain (and still harbour) anything explosive!
Tim
Old 06-22-2007, 12:37 AM
Rep: 10 Posts: 4
"So far, I see naughty miters. Use butt joints or lap joints on the corners!
Cable idea is fine, though more expensive and more prone to corrosion than 1/8"x 1" bar stock, which could be bent around easily and have a hole at one end and a coupling nut at the other." (? huh ?)
I was plannig on useing 55 gallon plastic barrels, but i still ahvent gotten my hands on any... i dont think metal would go over well with the rapids im going to be incountering maby pvc pipes? but do u think metal would be better choice/ easier to get?
Old 06-22-2007, 12:53 AM
alan white's Avatar
No, I thought you were referring to steel barrels. Sorry--- I'm over fifty---- when I grew up, a 55 gallon drum was always steel.
Yeah, poly barrels are the better choice--- slide better.
So the straps, they could be steel if those barrels have ribs that protrude more than the steel, right? Steel is nice because you can buy it galvanized and with holes every inch. Cheap. Then you can cinch the straps by bending the ends and using the available hole.
Another idea. You wrap conveyor belting over the bottom half of the barrels---- I've got some and it is some tough stuff. You'ks have to drive grommets through it to rope it on, but that stuff would slide over anything.
Old 06-22-2007, 06:58 AM
Rep: 10 Posts: 4
good i idea.... that would be perminate but i think since the raft is in 2 parts it would still be transportable. i was also thinking maby like thos motorcycle rachet straps.
Old 06-22-2007, 10:44 AM
timgoz's Avatar
What type (class) of rapids are you contemplating running?
Tim
Old 06-22-2007, 11:25 AM
Rep: 10 Posts: 4
1-2 i am planning on avoiding them altogether if possible.
Raft down the Mississippi qwist04 Boatbuilding 229 07-28-2011 02:58 AM
Raft/Junk Raft Building djwkd Wiki 5 03-03-2011 10:47 PM
More of a raft really... ace rockola Boat Design 7 03-22-2007 02:32 AM
New collapsible kayak project alexchet Boat Design 3 10-18-2006 01:53 PM
the raft so far... CaptainTweak Boat Design 23 08-16-2006 08:26 AM
