Old 05-13-2007, 10:12 PM
Skools Out Skools Out is offline
Rep: 10 Posts: 2
Cold Mold
what thickness wood do you skin the hull with on cold mold hulls?
Old 05-13-2007, 10:38 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
It is based on the ease in which the wood can bend at the most rounded part of the hull, and other factors such as direction of the layer and structural purpose of the layer involved. No two designs are necessarily alike. Quite thick or very thin.
I'm no expert though. Some here have probably designed and built cold molded hulls, and they can help you further.
Alan
Old 05-14-2007, 06:27 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
For most boats I would recommend only three plies in the plywood, then it's easier to bend. That means normally 3 to 4mm thickness.
See for example http://www.dixdesign.com/radply.htm.
In Didi 26 the round bilge is made of two layers of 4.5mm plywood, or 4mm if you can't find 4.5. Just an example.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 05-14-2007, 09:10 PM
Rep: 1397 Posts: 7,215
Large double planked hulls can have 2" layers. They are all different depending on size and use.
Old 05-14-2007, 10:13 PM
alan white's Avatar
I am looking at different methods of planking a St Pierre dory. My first thought is to go with two layers, both vert. grain fir. Might be vertical 5/8" inside and 3/8" fore and aft outside, spiled for aesthetics. Never done it before, so any thoughts...?
A.
Old 05-15-2007, 04:19 AM
Raggi_Thor's Avatar
Isn't that a hard chine hull?
If so, you will save time using plywood.
www.MBOATS.no
Old 05-15-2007, 04:20 AM
Raggi_Thor's Avatar
Originally Posted by alan white View Post
I... fore and aft outside, spiled for aesthetics. ....
I missed that part, fore and aft planks may look better :-)
www.MBOATS.no
Old 05-15-2007, 04:36 AM
alan white's Avatar
The first layer probably ought to be plywood, I guess. A lot easier. The spiled layer, maybe solid wood (dories wouldn't have much edge-set to the planks).
A.
Old 05-15-2007, 11:03 PM
Rep: 10 Posts: 2
thanks for this info so far.
Old 05-16-2007, 12:05 AM
alan white's Avatar
Start with the boat, S.O., and you'll get some good advice from someone here who knows cold molding. What boat design is involved?
A.
cold mold process gharr8 Fiberglass and Composite Boat Building 4 10-07-2006 12:35 AM
Cold Galvanize MorganFab Metal Boat Building 4 10-02-2005 02:35 AM
My hands get cold Thunderhead19 Software 14 04-27-2005 04:38 PM
cold mold VS Infusion>>strength/weight/cost compwest boats Materials 0 03-11-2004 12:23 PM
28 foot cold mold lprimina Powerboats 20 02-18-2004 10:43 AM
