Old 01-18-2012, 11:41 AM
danilo danilo is offline
Rep: 10 Posts: 8
Closed end rivets
Hi guys,
I am wondering how good the closed end rivets are to re-rivet a aluminum boat.
Does anyone have any experience with this ?
I'm gathering info because i wanna re-rivet a aluminum boat.
Do they form a water tight construction ? What is the expected lifespan compared to the original rivets ?
Thanks
Old 01-18-2012, 10:19 PM
Rep: 1493 Posts: 7,447
What is a closed end rivet?
Old 01-19-2012, 12:47 AM
Paul Anthony Paul Anthony is offline
Rep: 52 Posts: 7
A closed end, blind, pop rivet. I would recommend a high strength version for sheet aluminum or any soft, thin material. I worked at Fastenal for several years
Old 01-19-2012, 12:48 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 591 Posts: 1,021
something like this http://www.yilianmaoding.com/productinfo.asp?id=82 I think Danilo needs the Alu mandril type
Old 01-19-2012, 12:58 AM
Mr Efficiency Mr Efficiency is online now
Rep: 246 Posts: 710
The steel mandrel type would have to be excluded for sure. Need to talk to a manufacturer to find out about what alloys ( or pure aluminium) are available best suited to the job. I have never seen a rivetted aluminium boat with pop rivets, whether that is just a cosmetic thing, I don't know. The tolerances for diameter and roundness of the hole would be pretty tight to stay watertight, I think. Sounds like a tough job.
Old 01-19-2012, 03:46 AM
waikikin's Avatar
12 easy steps............http://www.youtube.com/watch?v=NPfPryTRcY4
Old 01-19-2012, 04:33 AM
Rep: 246 Posts: 710
Hmmm...I dunno. That video was pretty damned unimpressive, no close ups at all. Riveted aluminium boats went out with valve radios in Australia, everything from the mid 60's on was welded, below waterline anyhow. I suspect pop rivets need something stronger than alloy mandrels to pull them up nice and tight. OK for temporary repairs, maybe, with pop rivets, but if there was a pop rivet system that worked for boats long term we'd have seen it on production boats where rivets are still in fashion, like north America.
Old 01-19-2012, 05:11 AM
waikikin's Avatar
I agree... , solid rivets are superior, a fresh pop rivet has to be better than a dead solid rivet, the vid is pretty light weight I thought too- maybe I missed a winky face there. Welded/stretch formed & pressed panel boats seem to be a pretty well evolved production technique, an old Mates Dad was part founder of Quintrex & had an interest until the 70s, there's plenty of veteran welded "Fishabouts" still serving their owners well. All the best from Jeff.
Old 01-19-2012, 05:39 AM
Rep: 10 Posts: 8
Thanks guys
guess i have to talk to the manufacturer to find out more
about the application of closed end rivets.
Still,if there is someone out here with experience with c.e. rivets
please let me know.
Old 01-19-2012, 10:21 AM
I've used them for repairs on light boats, like canoes. I don't think they are adequate for the whole re-rivet job. It is not that difficult to peen rivets with a hammer and a backing iron, just time consuming.
Old 01-19-2012, 10:47 AM
Rep: 10 Posts: 8
Thanks gonzo,
I think i'm gonna go for the solid rivets after all.
Like you say you get a better job just add a little more time.
Old 01-19-2012, 12:53 PM
waikikin's Avatar
Originally Posted by danilo View Post
Thanks gonzo,
You may be able to make some simple tooling for a cheap small air hammer- with the inlet pressure regulated carefully to speed the process up.
Old 01-19-2012, 02:28 PM
When you get the hang to peening rivets, it goes pretty fast. It will be the same as copper rivets in a wooden boat.
Old 01-21-2012, 11:43 AM
aka Terry Haines
Rep: 1811 Posts: 3,006
I’m not sure I would want to fill a boat with water just to see if it leaks; that puts a considerable strain on the hull especially if its fastenings are already suspect. Much easier to take a wax crayon out next time I use it and mark the leaks on the inside . . .
Shouldn’t backing washers be used on soft materials like Al?
Dances with Turkeys
Old 01-21-2012, 05:37 PM
Rivets should have an adequate size head.
Rivets For Sale Kysam Marketplace 0 07-09-2010 10:29 PM
Replacement Rivets Cheapshot Metal Boat Building 1 04-19-2010 02:27 AM
Box Rivets cac Boatbuilding 0 12-04-2006 08:57 PM
rivets or screws? muskieslime Boatbuilding 10 08-11-2006 12:47 AM
removing rivets nighthawk Boat Design 2 04-19-2005 09:17 AM
