Water inside or outside....same result. |
Not to mention the boat being designed more for external compression rather than internal expansion. If you filled it with water the rivets would be in tension as the pressure tries to push the skin from the ribs. If the pressure is on the outside the rivets are under no stress as the skin is being pushed to the ribs. However I agree the boat should be able to withstand the test but its not same same. |
But this is why it is a good test. The amount of water, depending upon how much you fill the boat and if it has any dividing BHDs, (my little fishing boat had 2, one fwd, for the anchor/flares etc, and aft, for the engine catch-all), provides a good "over-load" test. If it passes, you're fine. If it doesn't, then the whole structure under "normal" loading conditions would be very suspect indeed. Quote:
As for the internal structure, as these being "designed" for compression. Therefore, there must be something, ie a bit of structure, that is required to resist that compression load, otherwise it'll just collapse, that would be in tension. So that "something" is the weak link, as that must now resist compression loads rather than tensile loads. However on very small boats, there is a limiting case for this and the reverse loading may be detrimental as you point out. But i'm not 100% convinced from all the small boats I've seen built this way. |
| I started my career as an aircraft sheet metalworker where in some instances there is no choice but to use mandrel-formed rivets but for pressurized areas these have aa alloy steel locking ring to prevent the mandrel backing off and are made from aluminum alloys that are not saltwater-friendly. There are some all alloy versions but they are low shear, low tensile formed and again made of a material not suitable for marine use. Regular aluminum "pop" rivets also have a steel mandrel that breaks under load leaving the head in the rivet tail so not only would you risk leakage from a poor seal but also ferrous oxide on the mandrel head and corrosion in the aluminum rivet from dissimilar metals immersed in saline. Short answer; you'd be mad if you do |
| Where I live lots of people run riveted Lund boats on the ocean. After a few years of overloading and pounding in the waves the rivets come loose. The easiest way to find the leakers is to pull the boat up the beach on a few rollers (pipe, logs, etc) and fill it with water. Look underneath and see where the drips are. Most people use a small machine screw and nut (if you are lucky you might have stainless ones) to replace the bad rivet. If you put a little bit of your favorite goop on the screw before you tighten it down they don't leak a bit. Be sure to use nyloc nuts to prevent them from coming loose. C.O. http://whatsintheshop.blogspot.com/ |
. Filling a boat with water is a bad idea. Bed your rivets in the correct diameter hole and you should have no problems. If the holes are out of round, redrill and upsize the rivet. |
| Don't FILL the boat with water, just put a little in the bottom to find where the leak is. |
| Rivets For Sale | Kysam | Marketplace | 0 | 07-09-2010 10:29 PM |
| Replacement Rivets | Cheapshot | Metal Boat Building | 1 | 04-19-2010 02:27 AM |
| Box Rivets | cac | Boatbuilding | 0 | 12-04-2006 08:57 PM |
| rivets or screws? | muskieslime | Boatbuilding | 10 | 08-11-2006 12:47 AM |
| removing rivets | nighthawk | Boat Design | 2 | 04-19-2005 09:17 AM |
