| Chain plates fastened to hulls or deck fittings I saw this quote on a boat plan web site - "Sail boat chainplates fastened to the hull are rare nowadays" I suppose the alternative is a through deck fastening Is this a pretty accurate statement these days ? What do you feel the implications are for either method ? |
| yes that is true....many yachts are running plates through the deck, ring framed inside the hull, certainly external chainplates are a thing of the past (sad really as they are the best for long range cruising, easily identified if problems occur and easy to fix)
| They have been through the deck for years and years. Works well for sheeting in larger headsails for going to weather. Tough to keep 'em from leaking, getting water in core and ruining the decks. -jim lee |
| interesting question R can't wait to hear what else folks have to say about this I like the old school designs but Im all about making the modern improvements
__________________ I am skeptical of the deniers diatribe |
| Fashion Again Quote:
When you have the furniture apart to repair the water damage it is a simple mater to install external chain plates and eradicate a mager design flaw whilst giving your boat some character, Its better all around?:-\
__________________ A/K/A .THE CURMUDGEON |
| Composite chain plates are also very common now as they solve the leak problem. Locate them on the hull sides or inboard depending on your rig and sail plan, or your preference. I like them on the hull. |
| Yes. Some of the more modern fast boats have composite chain plates molded into the hull at the deck edge because their headsails are small (no overlap), and are led inside for the best sheeting angle. Inboard chainplates were used extensively during the days of large overlapping genoas because they sheeted aft of the mast. In some cases today it is carried on because it helps keep the side decks clear for fore and aft passage. |
| I like the chain-plate outside and with a channel on the side. I like the chain-plates long enough to the waterline almost. And always bolted. The channel has the advantage to distribute the load to a great length on the outside, by going on several frames. It is a very old fashion, but work miracle by lowering the stress on the hull significantly, and the channel spread the shroud more outboard lowering the stress on the mast. Also the channel allow to have high bulwark not in the way of the shroud. I will don't do on other way to have the best chain-plates, always worked very well. I am talking for wood, steel and aluminum vessel. Not fiberglass vessel. Daniel |
| I have this as a background on my laptop ![]() |
| So external is best if the head sails are small enough that the sheets run on the inside anyway ?
| Locating Chain Plates | Bomber | Boat Design | 9 | 01-22-2010 05:23 PM |
| Bolt layout for chain plates | powerabout | Boat Design | 18 | 08-17-2008 02:43 PM |
| Mast step, compression Post, chain plates | skygusty | Boat Design | 2 | 08-13-2008 08:43 PM |
| chain plates | Scofield | Sailboats | 3 | 03-31-2008 02:56 PM |
| Catamaran Chain Plates | Eezee | Boat Design | 6 | 07-17-2004 12:20 AM |
