Old 05-10-2008, 03:48 AM
graemey graemey is offline
Centreboard keel???? Please help
Hey there guys.
I have a 6 ft or so fibreglass boat and i noticed it is missing the middle fin/centreboard, im new to boating and was wondering do i need one? does it improve stability? thanks
Old 05-10-2008, 07:15 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
Ah - bit more info ... sail, power, paddle - can you send a picture.
Not a lot ot go on my friend!
Old 05-10-2008, 10:53 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
If there is a slot through to the bottom ,you don't have the dagger board (as it's called when it doesn't swing but lifts straight out), then you have a sailboat (more properly a sailing dinghy or pram).
You therefore have a sail and a rudder.
If so, find a plywood board that will slip loosely into the slot, and screw two 3/4" x 3/4" cleats on each side about four inches down from the top, and make a slot for your hand to lift the board out.
The board can be 24" longer than the height of the slot it fits through. It should be rounded off on all of its edges and painted well. The edges could be fiberglass-taped as well with two layers, prior to painting.
Alan
Old 05-11-2008, 12:51 AM
Rep: 2891 Posts: 8,792
No, it doesn't add anything to the stability of the boat. Most every boat that size will be "tender", a term we use to describe an easily tipped boat. It's a function of size mostly in very small boats.
FJ centreboard susho Fiberglass and Composite Boat Building 0 10-04-2007 01:00 PM
centreboard ballast design frank marsden Boat Design 0 05-22-2006 08:15 AM
Keel & Centreboard fouling? Mike McKeon Boat Design 2 04-16-2006 09:33 PM
Centreboard optimisation abindoff Boat Design 11 03-26-2006 10:15 PM
Catamaran Centreboard Location TaSSie_deVil Multihulls 6 02-05-2006 07:38 PM
