Old 09-05-2006, 09:46 PM
mrdeepseafisher mrdeepseafisher is offline
Rep: 10 Posts: 2
Can I install a transom door?
I have a 1979 Trojan flybridge with a single engine 454 Mercrusier inboard. It also has a Teak swim platform on the rear and we have to climb over the transom and railing to get on the rear deck. My Dad' s (much larger) boat has a thru-transom-door and my wife has asked if we could do the same. I have checked the rear deck level and there is approx. 15-16 above the standing water line. I have done quite a bit of fiberglass work both polyester and epoxy resins so I don't think I would have trouble with the project.
My concern is what would it do to the value of the boat and/or would it detract from the structural integrity of the hull. I have had both postive and negative feedback and would appreciate this forum's opinion.
thanks
Old 09-05-2006, 10:39 PM
Rep: 95 Posts: 462
i wouldnt cut away on your transom , u are playing dangerous with the structual ,maybe you could make a gate with the railing and a step moulded from fiberglass
TV install travis1 Electrical Systems 2 03-13-2006 08:51 PM
Fiberglass door Gregory Walter Fiberglass and Composite Boat Building 6 11-27-2005 04:32 PM
Hull side Dive door gerard baladi Boat Design 3 08-01-2005 05:13 AM
Rotten door bottom Guest Wooden Boat Building and Restoration 2 11-18-2004 07:13 PM
Water tight bulkhead door kudu Boat Design 12 06-27-2003 09:46 PM
