| Calculation problem ? I plan the boat and I use Max surf to the planning of the hull. From the program I got to the hull structures LCB (LCB=2,644m). I calculating of the all other part LCB (stiffening,motor,payload and so on) by hand. This hand calculate LCB is 3,125m. How can I combine these two values ? what is to the boat real longitudinal center of buoancy ? Thanks from all answers Japix |
| Aren't you mixing up LCG (ling. centre of gravity) and LCB (long. centre of bouyancy). The first is dictated by the weight distribution, the second by the shape of the hull and how it floats in the water.
__________________ Dutch Peter “The opinion of the majority is not necessarily correct” – Yi Qing Cui |
| OMC Johnson 50 hp 2001 engine problem | Guest | Powerboats | 8 | 11-05-2008 09:57 PM |
| Need help with new boat porpoising problem | ferrazz | Boat Design | 27 | 04-15-2007 07:39 AM |
| Performance/Handling Problem | Boa | Powerboats | 11 | 08-10-2006 07:36 PM |
| Water in Oil Problem | ScCoghill | Propulsion | 3 | 06-05-2005 02:09 AM |
| Sea trials-one major problem | Powerboats | 6 | 05-10-2004 01:35 PM | |
