Old 12-28-2005, 08:01 PM
Troutcatcher Troutcatcher is offline
Rep: 12 Posts: 76
C-flex "one-off" fiberglass construction
Is there anyone out there that has some experience with building from c-flex?? With respect to amateur construction, does this building method offer any advantages compared to one-off foam core sandwich??
Old 12-28-2005, 09:08 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Bead and Cove Core-Cell is hard to beat!
Slippery when wet.
www.cheetahcat.com
Old 01-01-2006, 12:55 PM
Rep: 12 Posts: 76
"how to" fiberglass video/dvd
Happy New Year!!!
I am interested in "one-off" fiberglass boatbuilding methods. We all got to start somewhere.........Does anybody know where I can obtain a "how to" video or dvd describing either some variation of the "foam core sandwich" or "c-flex" methods????
Thans in advance,
Best regards
JS
Reykjavik
ICELAND
Old 01-09-2006, 03:46 PM
CET CET is offline
Rep: 10 Posts: 114
There are books and videos available on the topic of uing C-flex. I believe they were produced by the company that makes C-flex. I don't know the name of the company but if you track it down I'm sure they could point you in the right direction.
Old 01-09-2006, 05:43 PM
Nels Tomlinson Nels Tomlinson is offline
Rep: 10 Posts: 30
Many years ago I participated in a boat building class in which we built a small catboat using cflex and polyester resin. The boat is still afloat, and I think it has never had a blister, despite being in the water full time for two decades.
I think that cflex gives you a rather resin-rich hull, so you don't get quite the same strength-to-weight ratio that you could with another sort of glass. Backyard layup usually seems to make for a resin-rich hull, anyway, so I'm not sure it makes sense to go with a product which reinforces that.
If I were to try it again, I'd try glass and epoxy over strip planking.
Nels
Old 01-09-2006, 08:29 PM
Rep: 12 Posts: 76
C-flex
CET,
A video on construction with c-flex is available from Sintes Fiberglass Designs, Louisiana..........This company also has available frame kits for "one-off" fiberglass boats constructed this way. One beautiful design particularly worth mentioning is the "Sportsman 18" Carolina sportfisher-type boat with smooth, elegant lines.
Naval Architects Dubai chrisalex Services & Employment 25 03-28-2007 09:36 PM
SNAME Small Craft Papers CD sorenfdk Boat Design 6 12-29-2005 04:33 PM
Mould less fiberglass construction RAVenous Fiberglass and Composite Boat Building 10 11-24-2005 10:55 AM
fiberglass construction everglades1 Boat Design 0 09-21-2004 03:49 PM
Books on Fiberglass repair and construction? Boatbuilding 4 03-24-2004 04:48 AM
