Old 05-30-2011, 01:39 PM
CatBuilder CatBuilder is online now
Rep: 1320 Posts: 3,037
Bumpy Layup
What do you do when you have a bumpy layup?
I have a few spots where the glass isn't touching the core, but when I grind them out, there is no air inside. The bubble is filled with resin. Bad squeegee job.
Can I leave them?
"You can't solve all of life's problems with epoxy" - My Wife
Old 05-30-2011, 06:33 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,354
If there is(or going to be) more than one layer of glass I would grind it flush and not worry about it.
Hoyt
Old 05-30-2011, 07:28 PM
There are no more layers of glass. There is only one very thick layer of triaxial on the boat. Nothing else. Just bog/fairing and paint over the bump.
I don't care about the few little bumps, cosmetically, since they are inside the hull and hidden from view by cabinetry.
Structurally... am I in good shape to leave them?
Old 05-30-2011, 07:30 PM
hoytedow's Avatar
Resistor
How big are the bigger ones?
Hoyt
hoytedow's Avatar
Resistor
How numerous are they?
Hoyt
Old 05-30-2011, 10:01 PM
Rep: 1493 Posts: 7,447
Grinding the glass, particularly if it is only one layer, will cause a structurally weak spot. You should bevel the edges and laminate a patch.
Old 05-31-2011, 05:36 AM
I did bevel and patch one void. Thanks for the advice there.
These resin filled voids are at largest, 10cm long, 1/2cm in width and 1/4cm in height. There are six of them. The smallest is 3cm long by 1/8cm high by 1/2cm wide.
Do I have to grind, bevel and patch, or can I leave them alone?
Old 05-31-2011, 06:18 AM
hoytedow's Avatar
Resistor
I would leave them alone, especially if they are horizontally aligned, but I would do it the way Gonzo said if I did anything.
Hoyt
Old 05-31-2011, 07:31 AM
A bit of extra resin is not a major problem. As long as the laminate has good adhesion to the core, it should be OK.
Old 05-31-2011, 03:34 PM
Thanks, guys. Looks like I did grind one of them by mistake the other day. I sheered off the glass and now am just looking at resin. Guess I'll patch that one. The rest, I'll leave alone.
Hoyt: They do run along the 0deg fibers in my cloth, so I'm lucky there, I guess.
Layup on polystyrene eberd Materials 37 02-14-2011 03:51 PM
A Few Layup Questions CatBuilder Fiberglass and Composite Boat Building 50 01-04-2011 05:46 PM
Layup process???? jyoung Fiberglass and Composite Boat Building 17 08-22-2010 11:12 AM
Hull Layup HURRICANE Boat Design 1 01-23-2006 02:26 PM
glass layup conyermud Fiberglass and Composite Boat Building 7 12-30-2005 12:54 AM
