Old 12-02-2011, 11:07 PM
sail102's Avatar
sail102 sail102 is offline
REBEL!!!!!!!
Rep: 42 Posts: 62
building a Yankee Pine!
hi im building an 8 ft rowing skiff. I discontinued my pdracer project to build this skiff. I used the same side pieces but I cut the original pdracer bottom to form the shape of a skiff. Im really excited to see how this turns out and I will have pics of it when its done...if youve read the american boys handy book(which you probably havent) then you will find it to be very similar to the yankee pine.
it will be awesome!
Old 12-04-2011, 11:31 AM
sail102's Avatar
REBEL!!!!!!!
Rep: 42 Posts: 62
oh and I also want to make a sail for it
Old 12-04-2011, 05:22 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Don't wait until you're done; post pic's as you go.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 12-04-2011, 05:57 PM
sail102's Avatar
REBEL!!!!!!!
Rep: 42 Posts: 62
Ill try...
Old 12-04-2011, 06:02 PM
sail102's Avatar
REBEL!!!!!!!
Rep: 42 Posts: 62
this is on paint but that is the basic shape
Old 12-04-2011, 08:12 PM
sail102's Avatar
REBEL!!!!!!!
Rep: 42 Posts: 62
Boat...
Old 12-04-2011, 08:14 PM
sail102's Avatar
REBEL!!!!!!!
Rep: 42 Posts: 62
Looks a lot better than a pdracer! But that's just my opinion
Old 12-04-2011, 10:24 PM
sail102's Avatar
REBEL!!!!!!!
Rep: 42 Posts: 62
What should I name her? And also what color should I paint it?
Do you guys still think I'm loco?
Old 12-05-2011, 07:48 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,840
To all those who read the post that was here... pardon my mumbling...my foot was in my mouth.
Steve Lewis
Lewisboatworks
http://angelfire.com/ego/lewisboatworks
Last edited by lewisboats : 12-05-2011 at 09:31 AM. Reason: Removing foot from mouth
Old 12-05-2011, 09:18 AM
lewisboats's Avatar
Obsessed Member
Extrapolating what I see in the picture... I come up with this. Scary...but it could work.
Specs for the drawing:
transom 1.5 ft wide
max beam 2.5 ft
waterline length 7.65 ft
draft 5.1 in
Depth overall 15 in
freeboard 9.9 in
displacement 302 lbs (Salt) 295 lbs (Fresh)
What kind of sail are you expecting to use?
Where are you planning on putting it (mast position)?
What kind of board?
Steve Lewis
Lewisboatworks
Old 12-05-2011, 12:15 PM
Rep: 749 Posts: 1,314
Steve; your rendering is a good one but I think the boat is going to be ..shall we say....tiddly. At 30 inch beam it is more canoe than dinghy. It looks good that way however. I have no quarrel with the plumb sides. That is a practical solution for simplicity.
On my drawing board there is a similar teeny dink that is contrived to fit into the back of my Honda Element. It has 40 inches of beam and will generate less than 180 foot pounds of RM at 20 degrees. Obviously it can not use much sail. The skinny one you have drawn will be able to handle even less sail. I considered a narrower boat at considerable length but I concluded that my absence of enthusiasm for swimming was reason enough to make it wider.
Old 12-05-2011, 01:15 PM
Rep: 3125 Posts: 9,391
Considering Sail102's experience level across several areas, I think it's pretty foolish to make a sailing rig for this boat, based on that level of inexperience.
This is the same poster that wanted to put a spinnaker on a 5' catamaran (self designed of course), also a lanteen sail on a 36" mast, etc., etc., etc.
What design is this 8' "Yankee Pine" look-a-like? What you think is similar to a Yankee Pine, may in fact be quite different in several possably key respects.
What I see going on in that photo is a massively over framed 8' boat. It may not even float when you're done. If it does, will it have enough freeboard to tolerate a 3 MPH breeze? How about a person sitting in it? Sweet God, 2x4's in a 8' dinghy and you're going to put a rig on it? Stay within swimming distance of shore buddy.
Old 12-05-2011, 10:38 PM
sail102's Avatar
REBEL!!!!!!!
Rep: 42 Posts: 62
Ok..I will ask you to only post about the main topic of the thread when I'm just asking fore advice. Please take that request into consideration.
Old 12-06-2011, 12:52 AM
What design are you building?
Old 12-06-2011, 07:59 AM
lewisboats's Avatar
Obsessed Member
I think all replies have been right on topic. We are discussing the boat you have started to build and the design processes that went into it aren't we? If you expect us to praise you for a drawing and a picture of few pieces of plywood and some 2x's then you will have to give us some of the reasoning behind some of the more unconventional aspects of your build and the processes by which you came to the decision to use them. We are also interested in the rest of what you had in mind for the boat to make it sail so we can get a better overall idea of what it is you wish to accomplish and how you plan to get there.
Steve Lewis
Lewisboatworks
spruce vs pine Charly Boatbuilding 24 09-22-2011 04:51 PM
Pine Plywood? DDcap Materials 14 07-25-2011 05:54 AM
Pine Tar in the UK? nedgrater Boat Design 3 11-30-2009 06:43 PM
longleaf southern pine wudenbote Materials 8 08-22-2008 11:41 PM
Southern yellow pine at HD? Bob S. Materials 6 02-20-2006 07:09 PM
