Old 04-18-2006, 09:22 PM
adam1 adam1 is offline
Rep: 10 Posts: 2
Building a transom
I was wondering what materail to use? Should I use wood or is it worth it to go with some foamboard or something else of that nature any reply would be help full thanks.
Old 04-19-2006, 07:35 AM
dereksireci's Avatar
dereksireci dereksireci is offline
Rep: 37 Posts: 163
Details
Please give more details about the project. I don't guess you are building a transom without it being attached to some sort of boat?
Type and age of boat
What sort of power
Condition
This will give readers more information to provide help.
djs
Old 04-19-2006, 09:04 AM
Rep: 10 Posts: 2
make of boat
It is a fiberglass 79 searay 19ft I/o with a v8. Iam doing it all the stringers and floor. This is the first boat I have done. I have did stuff with fiberglass before though. Just wanted know what are the best products to use for the transom. Thanks for your help
Old 04-19-2006, 11:37 AM
Rep: 37 Posts: 163
Plywood
Thousands of boats are still cruising the planet with plywood transoms in them. The key is to not leave any exposed wood for the water to attack. When you cut the hole for the outdrive coat the exposed edges well with resin. You can stick two pieces of ¾" marine plywood together with a sheet of 3 oz mat in between. Wet out the mat enough so that a bit of resin leaks out all around the edge when the boards are pressed together. Weight it and/or put some nails in temporarily. Since your boat is 27 years old I wouldn't go the foam route for the transom. You could use medium density foam as formers for the glass of the stringers as they would be easier to shape to fit the hull than wood, however plywood may be a better choice in way of the engine. As always, supoport the hull well before cutting out the old stringers or it may be a different shape when you are finished.
Be sure to search some of the older threads here for good info on replacing transoms and stringers.
Good luck.
Do I get a prize for my 100th post?
djs
Old 04-19-2006, 11:51 AM
antonfourie antonfourie is offline
Rep: 13 Posts: 169
One rep point .... but then you do give good advice so you deserve it ...
Shafts thru the transom? Buck Powerboats 147 09-07-2007 09:21 PM
Transom Construction trrich Fiberglass and Composite Boat Building 9 10-03-2004 03:14 PM
transom bammy the bass Fiberglass and Composite Boat Building 1 09-27-2004 05:03 PM
Transom Bracket fletch44 Boat Design 1 04-18-2004 09:09 AM
extending the transom Guest Boat Design 9 10-10-2003 06:40 AM
