Old 12-10-2009, 09:15 AM
Steve W Steve W is offline
Rep: 360 Posts: 686
Casey,Kurt Hughes is a proponent of cylinder molded plywood construction and has used it as a way of building one off female molds to layup composite hulls in,it may be a better option than the plaster.If you want to build the hulls in composites you will be wanting him to give you a layup schedule anyway so id suggest talking to him about how well the cylinder molded plywood molds worked out.Good luck.
Steve.
Old 12-10-2009, 02:49 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Try making the boats in strip planking method, very fast, accurate, incredibly strong....I can see no reason not to do so for 3 boats. If you were to go into production, then yes make a mould, but strip planking in cedar is fast and easy. Epoxy sheathed to finish it all off.
started building a mold now need help tedhelms Fiberglass and Composite Boat Building 0 09-02-2009 03:14 PM
Newbie- Need help on mold building pendelton Boat Molds 5 06-30-2009 04:11 PM
Mold building bbugg Fiberglass and Composite Boat Building 1 10-06-2007 07:19 PM
Mold Building bf123 Fiberglass and Composite Boat Building 5 07-26-2006 06:03 PM
building a mold goodwrch Fiberglass and Composite Boat Building 3 11-16-2004 03:06 AM
