Old 12-28-2007, 02:22 PM
alwayskaos alwayskaos is offline
Rep: 10 Posts: 9
Building a 40' Offshore Cat, Need help please...
I have a wrecked late model 40' racing cat that I have cut up and customized for a mold. Boat is 40'x12'. Externally the boat is complete and looks perfect with a new gelcoat.
Can anyone recommend a layup process, and possibly a steel support system? I tend to over do things in regards to engineering, but since this is a personal project with the primary builder myself, I need to keep expenses reasonable. Not exactly sure of layup layout. I was going to use a Biaxial Combo Mat for the first layer over the gelcoat. Not really sure. How thick would it need to be, and what would a thickness cross section consist of?
Any help would be tremendously appreciated!!!
Thank you!!
Old 12-29-2007, 04:05 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
I'm no expert in this but without knowing how many times (one-200?) you are planning to use the mold it's no simple answer..
Old 12-30-2007, 12:46 PM
Rep: 10 Posts: 9
1 need one boat from the mold, but I would like to make it proper in order to sell the mold after my hull is complete. If anyone has experience in this, please share. My hull is complete ans sitting on blocks ready to go.
Thanks again.......
Old 12-31-2007, 01:07 AM
TeddyDiver's Avatar
Gollywobbler
As a "thumb" rule: After gelcoat make a laminated layer as thick as the original hull (incase 40' hull about 20mm) Add "ribs" (2'' tubing laminated aswell 20mm c/c 500mm) Add steel frame to support the mold.
Old 12-31-2007, 12:48 PM
Rep: 10 Posts: 9
Thank you very much for the reply.
I guess thats about what I figured.
So would the 20mm laminated layer be all fiberglass?
Also, what exactly did you mean by: (2'' tubing laminated aswell 20mm c/c 500mm)?
Could a chopper gun help help time and costs down?
Sorry for all newbie questions, but some of you have much more experience than I do in this area,,,,,,,,just need to pick some brains!!
Once the bottom hull was laid up, I was going to weld up a frame structure consisting of larger perpendicular U channels ,which go under the hull from side to side. These would be welded up with paralell beams from front to back with casters on the bottom.
Thank you
Old 12-31-2007, 09:08 PM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
40 ft LOA? by 12 ft beam? for a monohul? A cat that length one would expect a beam of between 20 (skinney & OK for power only) to 26 ft beam or wider if racing hulls. Can't be bothered when I saw 12 ft beam for a cat - stupid that for cruising.
If powered race boat different ball game. Your play..........
Old 12-31-2007, 10:07 PM
Rep: 10 Posts: 9
It is a twin engine offshore performance race boat, similar to a Skater or Nortech.
wanted 32-40' Performance Cat molds powerman6464 Boat Molds 9 01-16-2008 10:10 PM
40' Offshore racing cat for plug alwayskaos Boatbuilding 1 04-12-2007 05:44 AM
Beach cat building sailinaggie Boatbuilding 5 03-08-2007 09:53 AM
Free 25' sailing cat building molds... Billy Bones Wooden Boat Building and Restoration 0 05-24-2006 12:05 PM
Offshore CAT help Catman Boat Design 0 06-26-2003 12:37 AM
