Old 08-29-2009, 07:08 PM
zulpas zulpas is offline
Rep: 10 Posts: 5
Bowsprit alignment
How critical is the vertical alignment between the center of mast on cabin top (I don't have the mast yet), tip of the sprit and bobstay fitting?
The bowsprit is 4" Sq. tube, there is 3" lower deck from frame "A" forward to bow. The longitudinal forces are transmitted to this frame and bollards.
When I align the mast base and the sprit perpendicular to frame "A", the forward end of the sprit is about 5/8"-3/4" off against the bobstay fitting. I tried to maneuver it to align all 3 points by moving the aft end to port and forward end to Stb., however, I think it is more important to have the sprit square against the frame and in line with the forces. In this case the sprit is going to be visibly off the bow center. Am I being too fussy here?
Old 09-02-2009, 08:05 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
I am having trouble imagining what the alignment problem is. In any event, having the Bobstay in alignment with the forestay is the most critical item on the agenda
Old 09-02-2009, 08:46 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
I don't think it's too critical (though I think it's a bit inelegant) for the sprit end to be a bit off. What about whisker stays? What about the fact that the jibstay puts a lot of lateral load on the sprit's end? That componant would be far greater than any slight offset to one side.
That's what whiskers are for.
The question is, why did it happen and could it be made dead-on by cutting some out of the frame? It would bother me just to know the sprit was off-center even if it didn't matter functionally.
Old 09-06-2009, 02:24 PM
Rep: 10 Posts: 5
Thanks. The misalignment between the bobstay fitting and center of the sprit is actually only 1/4" on distance of 7'. I think I can weld the sprit end fitting off the center to make up the difference and perhaps position the whole bowsprit off the sguare to the frame, say 1 Deg.
How it happened? I don't know, even having all framing restrained something must have moved during welding. The rest is all within 1/8", just the front 3'-4' are off a bit. As for the mast top and staysail is concerned, I am not sure how can anyone find thru alignment, with level and plum bob that is.
I thing this thread should have been in rigging section, I'll see if I can move it.
Old 09-06-2009, 02:58 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
No worries..
BowSprit Butch .H Sailboats 10 10-26-2008 04:23 PM
bowsprit redesign sw44 Wooden Boat Building and Restoration 5 01-13-2008 03:37 PM
Retractable Bowsprit 35 foot sports boat robbo007 Sailboats 10 11-04-2007 05:51 PM
Bowsprit design LP Boat Design 2 04-04-2007 10:25 AM
Alignment Blues Guest Propulsion 17 10-13-2004 07:46 PM
