| boat transom - 23 tsunami anyone worked on 23 tsunami transom before need to redo |
| 23 Tsunami Need info on this brand of boat has anyone worked on them ie transom decks hull. need to fix stress crack on transom possibly redo transomm. Boat has tramsom area built like old 23 formulas, pd's, has twinn on bracket originally came with twins hung on transom. |
| Do you have a specific question? Stress cracks, soft transom cores, etc. aren't "application specific". In other what works on on boat usually works on others, so the need to have worked on on your model is irrelevant. Pictures and specific questions will generate replies. |
| I just got a Tsunami and it needs a transom core. Have you made any progress on yours? |
| Yes I had transom redone go to Hermco.com in Jensen beach florida did the work and I also had them build me a new bracket on boat. Photos are there. |
| Awesome job! I saw those pics before and it sure looks like Hermco knows their stuff. Did you end up having any water-saturated foam issues? It looks like there's a tunnel running forward from the transom at the keel, how far forward does that go? I'm surprised that the stringers don't connect with the transom... I could ask you a million questions but I'll spare you! ![]() What kind of performance numbers do you get with the 150's? |
| Did nOt have water issues when transome was cut off. Don does very good work. If you did not know he and his old partner started contender boats in Miami. The boat runs suPer with the 150 I actually have another Tsunami a 1986 that had spake if 200 yamis and it flew but those were cArburated . With the 150 four st |
| With the 150 four stroke i am getting 1.8 mpg which is great range since I haw the large fuel tank. If you don't mind me asking where did you pick up the Tsunami and if you could send me am picture. also if you need a bracket I have a bracket from stainless marine in great condition for $2,000 |
| Hey, sorry I missed your reply, I didn't have email notify on. The Tsunami I have is a 1983, hull # 11 I think. It came from the Ft. Pierce area but I think the original owner was on the west coast near Ft. Meyers. You can see it on this thread over at THT. I plan to recore the transomn and stay with the 200 mercs hanging on it for a while. So far I have entirely de-rigged the boat and pulled out the fuel tank, which was badly corroded and will need to be replaced. They are foamed in there so tight that any leak would have been totally contained by the foam, but that's probably not a good thing! So you have 2 Tsunami's now? I'm envious! |
| Hey talk to don at Hermco ref transom wOrk The other tsunami I have is a 1986 same color black if you know anyone interested in one let me know. |
| Japanese Quake and tsunami | Mr Efficiency | Open Discussion: All Things Boats & Boating | 252 | 04-25-2012 12:37 AM |
| What would happen to this floating platform in a Tsunami? | Dr.Smart | Open Discussion: All Things Boats & Boating | 14 | 03-17-2011 05:34 PM |
| Chile Tsunami photos from Tonga - Calm | yachtwork | Open Discussion: All Things Boats & Boating | 2 | 03-01-2010 08:45 AM |
| Samoa Tsunami photos | yachtwork | Open Discussion: All Things Boats & Boating | 4 | 01-07-2010 02:50 AM |
| Tsunami warning from quake 3 hrs ago | SamSam | Open Discussion: All Things Boats & Boating | 9 | 04-02-2007 11:20 PM |
