| Boat made of toothpicks please view the attached file I have no clue how to start with the project i need help thanks Mariam |
| looks like you need to design a small boat that can received a dropped bottle of water from 15 cm high, that will not fail or allow any water into the boat when the water bottle hits the boat. You have to estimate the weight of the finished boat, determine the max load on the boat caused by the dropped bottle, and determine how strong to make it, and how much freeboard (or height of sides above the water surface) you will need to keep water out of inside. And than make it as light as possible, so you would want some extra height to prevent splashed water from entering it, but not too much since it adds weight. You might search the web for pictures of boats used in similar design/build contests. It will give you some ideas. good luck. |
| Thanx for ur help petros but im having a hard time sticking the toothpicks together and also how do i attach the vertical part of the boat ? ps-im using super glue |
| Might be best to devide the boat in two stuctures. The hull itself and a collapsing superstructure (like shock absorber) taking the impact of the bottle and to hold it in place after the impact. my 2c |
| Anyone needing fibreglass/carbon fibre work done!moulds made/products made etc? | roadracer85 | Marketplace | 1 | 12-24-2009 08:38 PM |
| Steel-made hull with fiberglass-made radius chine ? | xarax | Metal Boat Building | 48 | 07-23-2007 11:35 AM |
| Steel-made hull with fiberglass-made radius chine ? | xarax | Boat Design | 0 | 07-05-2007 01:43 PM |
| plug made.. mold made.. now what | mungral | Fiberglass and Composite Boat Building | 16 | 01-14-2006 09:24 PM |
| Boat Design using toothpicks for Physics Project | tpru2000 | Boat Design | 4 | 05-16-2005 09:46 AM |
