| Boat finishing layer My girlfriend and I are build a couple of small sailboats (7'8") to sail occasionally. They might be in the water for 2-3 hours every other weekend or so for a couple months, but then it will be winter and they wont touch water for months. We are trying to make them as cheap as possible also, so i dont want to fiberglass them. And becuase they are only going to cost like 50$ to build, i would rather not drop another 90$ on some fancy marine grade epoxy. Can anyone suggest a cheap solution to keeping the wood and paint safe for the 2-3 hours they are in water? I thought about putting multiple coats of clear coat, or varnish, or something like that. |
| Good quality porch paint. Make sure you give it a week or so to dry, but after that it will last for years as long as you keep it from chalking in the sun.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Porch paint? Is that what it is called? Iv never heard that before. Ill look for it when i go to town. thanks |
| It is used for painting porches...i.e. exterior floors. It is formulated to resist being wet for a limited time (a day or so, not full time immersion) and for hard wear. While not as good as some marine enamels, it is much cheaper and comes in water-based formulations (which is why it needs to throughly dry).
| Thanks for the info! This forum is useful. I wish i knew enough to add back to it. |
| My experience differs a little Thinned varnish can be brushed onto plywood to saturate the wood and then dry into a surface penetrating coat before barrier painting with an exterior grade primer and paint. Soaking all edge grains of the plywood before assembly with thinned varnish will let a low cost plywood boat last years more than a boat with just paint. Plywood failures generally all start on edges and voids - not flat painted surfaces, so a little prep work on the edges makes all the differences when using cheap materials. Two or three coats of thinned varnish, allowed to cure after cutting and before assembly is the best prep. Problem with paint-only is that even exterior grade paints form a barrier layer, but do not penetrate the grain of the wood. Thinned varnish penetrates the grain and makes a huge difference. -- CutOnce |
| When i see boats (like the PDRacer) that have a wood finish, do you think that they used multiple layers of varnish, or perhaps something else? Would varnish eventually build of and become a protective layer? |
| Use varnish as suggested. Make it thin so that it penetrates the wood. After the impregnation and the varnish is dry, add porch paint as mentioned. Varnish as a final coating is not anywhere near as durable as paint, so do not use it for a finish coat. The PDR builders are using all sorts of finishing techniques. A the cheap and dirty end, they slap on some house paint and call it good. At the upper end they will be artfully covered with fiberglass and epoxy, then painted to a fare thee well. Your boat at three feet wide and eight feet long is going to be pretty tender. You will be much more pleased by making it wider. As an engineering type, you will have no problem with calculating the immersed volumes. It should be apparent that the wider boat will float in shallower water and be much more stable and capable of carrying the 40 odd square feet of sail without causing you to swim frequently. |
| Messabout: Yeah havign a wider boat would make it float higher. today we took the boat out and water tested it, it only sank into the water about half an inch while empty and almost 1.5 inches while we sat in it. The sides at 10" ... so i think we have a good bit of space. =) Chiko |
| Looking for help finishing my boat.... | BCBound | Boat Design | 5 | 06-02-2009 11:15 AM |
| FreeShip layer characteristics | LP | Software | 4 | 08-24-2007 12:08 PM |
| Layer of Biax? | mtnrat | Fiberglass and Composite Boat Building | 2 | 06-02-2007 11:40 PM |
| re finishing 1985 bass boat | Wrightd | Fiberglass and Composite Boat Building | 2 | 06-04-2006 04:10 PM |
| Boat Finishing and Hatch Addition | Chris Krumm | Materials | 0 | 11-01-2003 12:46 PM |
