  #106
Old 09-28-2010, 08:43 AM
westsail42 westsail42 is offline
Rep: 10 Posts: 49
Nice looking project there!
I have rolled/tipped a 28 foot hull (not the topsides) with LPU with fairly good results, though it was the Sterling/Detco brand, not Interlux. I did it in one shot, all the way around the boat, with one person assisting. You can roll it in "sections" between hard edges if you don't mind a small tapeline on the corners. These little tapelines cannot be sanded/buffed out.
Are you planning to paint the topsides with this stuff? If so I might recommend spraying if the topsides are "busy" with rounded edges and corners. LPU is very high gloss and will proudly show off any imperfections such as holidays, curtains, and poorly sanded surfaces. I have seen some pretty ghastly LPU roll/tip jobs done on the topsides.
Note that the making of a good LPU job is "all in the prep" of the surface. Fair the surface as best you can, with high build primers if necessary. Do one more coat of primer than recommended. Careful sanding up to 220 grit. Sand by hand is preferred over RO sanders (I used a longboard).
Hope that doesnt put you off . Mind you I was somewhat of a perfectionist with this job I did, so my standards were high. If you are not that particular cutting corners may work ok. But keep in mind that, due to the high gloss nature, a "mediocre" LPU job can look really bad, even with the 50 foot test.
I have also heard that the Interlux formulation is more forgiving with roll/tip than the others, so that may make things easier already.
Having said all that, I encourage anyone to try a roll/tip LPU job. Its not black magic, you just need patience. Again, a good result is "all in the prep".
Originally Posted by BurnabyRocket61 View Post
Hello,
I bought this aluminum runabout several years ago, but soon realized that it wasn't quite the right set up for west coast salmon fishing. So I thought that I would take out all the salmon/cat piss smelling carpet and just paint all the existing plywood. I figured, what? a couple months work, no problem. Well, three years, and a bunch of bright ideas later, its finally ready for the topcoat.
I'm using Interlux Perfection. My plan was to roll and tip, but I'm wondering what my best plan would be. Do I work my way section by section, brushing into the corners, or do I work bow to stern, gunnel to gunnel a foot or two at a time to try and maintain a wet edge, which could be difficult by myself.
I also thought of having it sprayed, but I have read some feel that perfection doesn't spray that well and in fact looks better roll and tipped. I would like to finish it myself, but after all this time and work that I have put into it, I want the best finish possible even if it means paying someone else to spray it. What do you guys think?
Oh, and to let me know if you have any questions about the project, I,ll be happy to answer them.
Thanks
Building out a Westsail 42 Ketch
http://on.fb.me/hYZxpC
www.westsail42.com
  #107
Old 09-28-2010, 12:00 PM
BurnabyRocket61 BurnabyRocket61 is offline
Rep: 20 Posts: 19
Hello,
Thanks, for the reply. Very good advice concerning the prep work, and it 's been painstaking, 2 part prime and sand for hours, again and again. Friends have told me, " just paint the damn thing ". But I plan on being buried at sea in this boat, hopefully not for another 20- 30 years, so I have sanded every nook and cranny to the point where the entire boat, is as smooth as a babies bottom, and I would like it to remain that way after the final topcoats.
I have 6 days starting Oct 3rd to apply the final coats of the 2 part LPU, and the weather is supposed to be good, but after all the time and effort that I've put into this, if there are any tape lines etc. on the final coat, I'll kick myself for not having it sprayed.
Thanks
  #108
Old 11-07-2010, 08:59 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
This is a commersial build that I came across a while back. It's a Carolina Sportfisher being built by Jarrett Bay Boatworks for a Nascar driver Jeff Burton. The site has a lot of pics of the construction. The boat should be finished in next february.
Jarrettbay.com
Lurvio
Hopefully creating something useful, since 1983.
  #109
Old 11-14-2010, 08:03 AM
tiller98's Avatar
tiller98 tiller98 is offline
Rep: 10 Posts: 4
First time posting on this site. I'm excited to be here. I have a few projects underway and I even have a blog, pictures and videos! My very amateur designs include: a 14' power cat, an 18' hydrofoil sailboat, a stand up foilboard (not really a boat) and various other experimental craft.
http://corycraft.blogspot.com
  #110
Old 11-14-2010, 08:42 AM
aka Terry Haines
Rep: 1811 Posts: 3,006
Welcome aboard!
Dances with Turkeys
  #111
Old 11-14-2010, 02:15 PM
sean-nós's Avatar
sean-nós sean-nós is offline
Rep: 286 Posts: 103
Some interesting projects, You will fit right in here
  #112
Old 11-14-2010, 02:21 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,354
Agreed. Welcome Til.
Hoyt
  #113
Old 11-21-2010, 05:36 AM
tiller98's Avatar
Rep: 10 Posts: 4
Thank You
Thank you all for the very warm welcome. I was hesitant to begin posting as I am such an amateur. Nice to have a warm reception!
Contact me:
tiller98@gmail.com
  #114
Old 12-08-2010, 07:11 PM
viking north viking north is offline
Rep: 727 Posts: 1,161
Hi, my name is George, I am from a long line of Newfoundland boat/ship builders/captains(400 yrs.) and presently live in Nova Scotia. I am in the process of building/converting a 30ft. ships lifeboat/surfboat into a 50/50 motorsailer. Over the past 25 yrs. i have built/repaired many boats and converted several lifeboats into motorsailers both for personal use and for customers. I have worked in all mediums, wood, metal and RFP. This particular hull is not what one would visualize as a lifeboat, having a medium to fine entry and a canoe stern. I am keeping and have kept good photo records of all my builds and having an instructors background in woodworking/electrical/electronic/ mechanical/welding, as such I am naturally open to offering help and never shy to ask for input. I have finally reached a point in life where my income earning workshop has now become my hobby shop and i finally have the time, reasonable funds, and more than enought boat materials and hardware to build my retirement vessel . Forums are a new thing to me mainly a time issue and i am have been on another forum for the past month but have the feeling its sort of specialized and not as open as i visualized a forum would be. This thread is an excellent idea and the variety and quality of construction is just fantastic, good work all.
  #115
Old 12-09-2010, 05:43 PM
hoytedow's Avatar
Resistor
Välkomna, viking north.
Hoyt
  #116
Old 12-09-2010, 06:04 PM
Thankyou, my southern neighbour, It is a great country, great people and nice to see as we used to say in the 60's (more) power to the people. George
  #117
Old 12-10-2010, 05:45 AM
hoytedow's Avatar
Resistor
We see a lot of Nova Scotians(New Scots?) here in my town, of bottled water fame.
Hoyt
  #118
Old 01-05-2011, 06:53 PM
Fiberglass Shelburne Dory Build
Female mold taken off a traditional Shelburne wooden dory. These dorys were developed locally to transport one fisherman and five lobster traps. The spoon schooner style bow developed to row out thru surf. I built this as my personal exercise rowing machine, it is extremely easy to row and with a set of 9ft. oars regularly maintain an average speed of 3.5 knots over a 5 mile course daily and on several ocassions each summer myself and the Missus will pack a picnic and take a 10 to 15 mile sunday gunkhole.
Boat Building Projects Underway-dorey-interior-view.jpg  Boat Building Projects Underway-dcp_0002.jpg
  #119
Old 01-05-2011, 06:59 PM
Shelburne Dory Project
More photos of the amazing 18ft Shelburne Dory, The prototype shown in the water has three rowing positions, it was later modified to have two positions only. In heavy winds or with a passenger seated in the stern seat, the best rowing position is forward. I have often rowed offshore in 5 to 10 foot non breaking swells. My future plan is to install a drop centerboard and use a windsurfer fiberglass mast(just happen to barter one) with a loose footed main set forward much like a cat rig.
Boat Building Projects Underway-main-shop-dorey.jpg  Boat Building Projects Underway-dorey-stern-view.jpg  Boat Building Projects Underway-dorey-bow-view.jpg
  #120
Old 01-10-2011, 07:19 PM
Ships Lifeboat conversion to Motorsailer
THE FOLLOWING BUILD PRESENTATION IS A "AS I DID" ILLUSTRATION ONLY AND SHOULD NOT BE USED AS AN ENGINEERED REFERENCE FOR AN ACTUAL BUILD. As promised my 2nd. Conversion, 26ft.x8.5ftx5.5ft alum. ships lifeboat to motorsailer, launched year,1992, sold year,2000 for a planned trans Atlantic crossing. Photos will continue to be posted thruout the week as i find time. At this point in the build the hull had been steam cleaned of about 10 layers of white marine paint and was in transport to the shop on Newfoundland's south west coast.Geo.
Boat projects wanted in WI USA Bill Dunn Services & Employment 1 08-20-2009 03:39 PM
Seeking Projects: Boat Building:Glass/Epoxy/Carbon Composite BalticBoats Services & Employment 0 06-18-2009 02:59 AM
Trailerable daysailor underway... Wynand N Boat Design 40 12-01-2008 11:38 AM
Job Search Underway dantemclean Services & Employment 0 08-02-2004 07:50 PM
American Boat Builder in Brazil looking for partners or projects caribmon Services & Employment 1 02-06-2003 05:12 AM
