Old 03-17-2009, 07:34 PM
ygthaydut ygthaydut is offline
Rep: 10 Posts: 11
boat building method
Which one is the easiest and newest method for boat building? and whicp plan supplier provide like that plan?
Old 03-17-2009, 07:41 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
The newest proven method over a long history of boatbuilding would probably be stitch and glue frameless (or mostly frameless) construction, using plywood and epoxy and fiberglass cloth. There are certain to be some newer methods but you need not concern yourself with those if you are looking at starting a first-time project.
Old 03-17-2009, 07:45 PM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 603
stitch & glue glass over plywood construction
www.bateau.com
There's been a few of their TW28 designs built in Turkey in the last couple of years. Check out this thread....
http://forums.bateau2.com/viewtopic.php?t=9494
and this one....
http://forums.bateau2.com/viewtopic....ighlight=yavuz
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 03-17-2009, 08:15 PM
Rep: 10 Posts: 11
okey my friend I know bateau I know all boats of them is there different companies?
Old 03-17-2009, 08:25 PM
apex1
What are you going to build, sail,motor, and on which scale? Homebuild? Boatshop?
Are you in Istanbul / Tuzla ?
Old 03-17-2009, 08:35 PM
Rep: 10 Posts: 11
no I am from İzmir. for homebuild, I have a website which is about boat building materials. I looking for everything about boat building.
Old 03-17-2009, 08:44 PM
apex1
I understand, but no, for homebuilders I do´nt know any new methods.
Old 03-17-2009, 08:46 PM
Rep: 10 Posts: 11
thank you my friend . I am looking for new methods. easiest ones maybe I can find in this time
Old 03-17-2009, 08:51 PM
Rep: 578 Posts: 603
http://www.glen-l.com/
Old 03-17-2009, 11:06 PM
Rep: 2891 Posts: 8,789
Designers and engineers are always coming up with subtle changes to current methods and applications. I don't personally believe that taped seam (stitch and glue) is the easiest method for the novice or beginner. This of course is a well debated opinion, but after years of designing boats for home builders, the biggest issues I've found are "goo factor" related among the first time builders. The goo factor (my term for lots of messy adhesive and sheathing effort) is quite high on these methods, which isn't user friendly for a person with little experience.
I think glue and screw is much more user friendly for the novice builder and usually far cheaper too. These methods are a cross between taped seam and traditional plywood over frame construction. Generally the seams aren't taped, but screwed to battens with a bed of adhesive or sealant. There's typically more framing involved, but these wood working skills are more commonly found in the novice builder.
Can you list your web site address?
Old 03-17-2009, 11:22 PM
alan white's Avatar
I agree with PAR. While stitch and glue is newer as a construction technique, older methoods such as plywood on frame (chine logs, etc.), or even solid wood (as in typical traditional skiff design) are much better suited to the novice.
There are enough miracle adhesives out there to assist in sealing seams and joints that it's not hard to get a really water-tight hull nowadays.
You can progress towards epoxy joints later. Meanwhile, there are many uses for limited experience with epoxy and additives in even traditional construction.
Luckily, there are thousands of wooden boat designs with plans that don't require huge amounts of epoxy--- some can be taped with fiberglass just at the seams (tack and tape), and those do not depend on epoxy for strength, just for waterproofing.
Old 03-18-2009, 08:51 AM
Rep: 10 Posts: 11
Here is my adress : www.kenditekneniyap.com
Old 03-18-2009, 10:19 AM
Rep: 10 Posts: 11
What did you expect I dont know but first you have look very careful. Plans under affillate program. bateau company and joel knows this. I am waiting for your apologize.
Old 03-18-2009, 10:49 AM
Joel is a friend of mine, I'll call him this afternoon and find out the real story.
Old 03-18-2009, 12:37 PM
Rep: 10 Posts: 11
you can call where do you want to call. Just look for satın al link from my site it is going to bateau's page. I think you dont understand.
The Cutts Method, building & repair brian eiland Wooden Boat Building and Restoration 9 09-07-2008 11:52 AM
The Bourne Method of Boat Building la cage Boat Design 6 06-14-2007 11:34 PM
Best “One_Off” building method using foamcore jedkins Materials 6 02-03-2007 08:26 PM
Help choosing building method fede Boat Design 38 02-20-2005 09:20 AM
new boat building method Guest Boatbuilding 2 09-24-2003 03:55 PM
