| A word on stitch and glue: for the first time builder it is best to buy a kit. It's more expensive than buying the materials but less risky. If you make a stitch and glue boat from plans the planks must be marked and cut accurately. The resulting hull shape is determined almost entirely by the plank shapes. Most kits are for stitch and glue and go together reasonably well as they are generally machine cut. If you are working from a plan however, the battens that Par wrote about help to define the shape of the hull and ensure that is looks good. When you buy a plan the designer will specify the construction method and often supply detailed instructions. It is wisest to follow these. I admit that I don't, but I enjoy the mental battle fo solving the problems that often result from meddling with the designer's intent. =
| I apologize to Ygthaydut. It appears his site is in good standing with the folks over at Bateau2.. |
| apology |
| Okey then no problem . I am sorry too. |
| The Cutts Method, building & repair | brian eiland | Wooden Boat Building and Restoration | 9 | 09-07-2008 10:52 AM |
| The Bourne Method of Boat Building | la cage | Boat Design | 6 | 06-14-2007 10:34 PM |
| Best “One_Off” building method using foamcore | jedkins | Materials | 6 | 02-03-2007 07:26 PM |
| Help choosing building method | fede | Boat Design | 38 | 02-20-2005 08:20 AM |
| new boat building method | Guest | Boatbuilding | 2 | 09-24-2003 02:55 PM |
