Old 06-29-2010, 02:05 AM
colfar5033 colfar5033 is offline
Rep: 65 Posts: 51
Boat Building In Cold Weather
Morning gents
what does one do when it is cold and motivation is low and one is working outside Have been trying to do some epoxy work and have given that a miss
cheers
Old 06-29-2010, 02:52 AM
CDK's Avatar
CDK CDK is online now
retired engineer
Rep: 1416 Posts: 2,247
One builds a tent or shed around it and puts a heater in or waits for better days.....
Old 06-29-2010, 03:05 AM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1348 Posts: 2,048
Second that..
now isolating the tent
Old 06-29-2010, 07:15 AM
M&M Ovenden M&M Ovenden is offline
Rep: 527 Posts: 183
...I go skiing
More seriously, when it gets cold or it's raining I work on planning ahead the next building steps, I source parts and materials I will need next and I clean up so my work space is tidy when I can work again.
Enjoy the cold in a cozy chair, many coffees and work out what will come next. Do you know where you will have threw hulls? How are you powering your boat, picked the engine, prop...? How will the engine girders be fitted and built? What kind of tanks are you fitting in? How they going to be secured? Do you need to source those tanks? Do you need a propane locker and where to fit it? My oh my...just throwing ideas around but there are so many details that might need to be thought of and wouldn't it be frustrating to get there and have to bang your head "whats" and "hows" when the weather is just perfect to enjoy the hands on work? Make it so when the good weather comes, you have as little thinking to do and just motor threw the construction. As well planned as a project can be, there's always something more to be thought of. See now? you might be thinking about how to build a shed over the boat .
I built one boat in the cold and that was enough for me to give up fighting elements.
Enjoy,
Murielle
Old 06-29-2010, 01:31 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,354
Make or repair small parts, eye-splice ropes and research methods. Hang out here.
Hoyt
Old 06-29-2010, 11:25 PM
Rep: 65 Posts: 51
boat building in cold weather
like the idea about the tent .lucky here in africa winter is not to long and we are past midway so hoping for some heat soon. my biggest issue is to get my self motivated to get of couch and get out there. have some work i can do in garage and drag heater in there and can work on future planning. go skiing
Old 06-30-2010, 02:28 AM
TeddyDiver's Avatar
Gollywobbler
and of course your winter is warmer than my summer..
Old 06-30-2010, 10:06 AM
Tiny Turnip Tiny Turnip is offline
Rep: 536 Posts: 256
I understand the motivation problem!
For me, I can sometimes trick myself into getting stuck in, e.g. Come home from work, DON'T sit down (can make a cup of tea) and go and just do 15 minutes straight away, before you've relaxed,(chances are when you've started you carry on and do more, because you've remembered you enjoy it. And you are fired up to come back to it after supper, say.)
Or, if that's too much, just go and organise the tools, clean, sharpen, prepare materials, tidy the work area, get ready to do some....
Or, if that's too much, go and just look at the job, and think about it (cup of tea in hand.)
I find all the above whets the appetite for the project again.
And no hurrying! Nothing takes the fun out of a job more than having to rush! If there's enough time, just about anything can be satisfying, even the washing up.!
Anyway, that stuff mostly works for me. I do sympathise!
Good luck
TT
Old 06-30-2010, 05:39 PM
sean-nós's Avatar
sean-nós sean-nós is offline
Rep: 286 Posts: 103
You are in South Africa, I live in Ireland its cold and wet 350 days a year,build a lean to and work harder
Old 07-01-2010, 01:40 AM
Rep: 65 Posts: 51
Dont know what i am complainng about i could not handel so many cold days
Old 07-01-2010, 02:15 AM
liki liki is offline
Rep: 104 Posts: 167
Teddy,
how is your tent constructed and what do you use for heating? I'd need a temporary shelter for building a 4,5x1,6m boat to be able to work on it during the winter also.
Old 07-01-2010, 03:03 AM
TeddyDiver's Avatar
Gollywobbler
I'm now on a holiday in Virrat. I put some pictures when I get back.. PM send if you like to call...
Old 07-01-2010, 01:39 PM
sean-nós's Avatar
Rep: 286 Posts: 103
This is were I built mine, I put a tarp around it when fiberglassing and painting and just used a fan heater.
And if you like this is the build.
http://s753.photobucket.com/albums/xx179/fergalbutler/ I have just started another build so its holding up well
Old 07-02-2010, 10:56 PM
uncookedlentil uncookedlentil is offline
Rep: 8 Posts: 81
I just moved 3,000 miles to put -35 degrees below 0 into a distant memory
Old 07-03-2010, 06:21 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
Sam Devlin reckons that "to finish a boat, you really have to HATE it"
I can remember a few of those projects all right :-)
cold weather polyester resin use mkspike Fiberglass and Composite Boat Building 8 01-14-2009 08:16 PM
Heavy weather boat designs? anton hart Metal Boat Building 1 08-07-2008 07:24 PM
cold weather glassing rturbett Fiberglass and Composite Boat Building 5 03-11-2006 08:46 PM
Building cold-molding "monocoque" jusembo Boatbuilding 10 10-07-2004 05:39 AM
Trailerable Cold Weather Offshore Fishing scott webster Powerboats 3 03-22-2004 01:37 PM
