Old 08-02-2010, 12:20 AM
SeaJay SeaJay is offline
Rep: 112 Posts: 211
Bilge Sump - Canoe Body
Guys, I'm stumped on this one...The hull of the 46' motor sailer I have under construction is really flat at the lowest level of the bilge. I estimate that before water would build up to a depth of 1" at the lowest spot, it would cover an area maybe 10ft long by 3 ft wide. I can sort of corral it by directing it along stringers and through limber holes but unless I can find a pump that will pick up a half in inch of water, I think any random bilge water is just going to slosh around forever. (I'm just talking about nusiance water here.)
I suppose I could cut through the bottom and form a small sump that would nest inside the top of the keel, but the thought of taking a saws-all to that part of my boat just doesn't appeal to me one bit. Short of this, does anyone have any suggestions?
Best Regards,
SeaJay
Old 08-02-2010, 01:20 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Best Regards,
SeaJay
A good diaphragm pump should be able to pick up anything over 1/4", I would think. I wouldn't want to have it on auto for anything that shallow, though.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 08-02-2010, 04:44 PM
Rep: 1493 Posts: 7,447
That's the problem with canoe bodies without bilges. They get a little water in and splash all over the inside of the boat. A sump in the keel may help some, but when you are rolling or heeling over, the water will still splash around.
Old 08-03-2010, 12:07 PM
Rep: 112 Posts: 211
thanks guys. You're pretty much confirming what I thought. I'm afraid this is just a fact of life that I'm going to have to live with
Old 08-03-2010, 12:53 PM
apex1
Leave it as it is,
almost all modern mass production sail boats have that sort of (usually non existant) problem. commonly that is a very dry space.
Regards
Richard
Old 08-03-2010, 02:28 PM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1348 Posts: 2,048
If you really have some water you could make a raised sump. It's basicly a what it sounds like, a raised sump with sloping outer sides. X figured "stringers" guiding water toward the sump. Heeling and pitching run water in..
Old 08-04-2010, 10:41 PM
Rep: 112 Posts: 211
Teddy,
This is a clever idea! I think I can do something like this. Thanks!
Suggestions?-Engine Sump/Bilge SeaJay Boatbuilding 4 09-05-2008 01:04 PM
Powerboat shaped canoe body vs Mac Gregor vs Sailing vv3k4i Boat Design 4 03-12-2008 04:36 AM
better body plan CapKos Boat Design 4 05-07-2007 03:34 AM
glassing over body filler? LKJR Fiberglass and Composite Boat Building 4 05-27-2005 02:47 PM
Affixing full keel to canoe body RDB Boat Design 0 05-17-2004 05:58 PM
