| Best Temporary Cove Joint Material? One more thing I need to do in order to move hulls around: I need to put temporary bulkheads in. How should I do it? Cove them in like normal bulkheads using...?? Later, how do I break them out easily without damage or contamination? Not sure how to do temporary bulkheads.
__________________ "You can't solve all of life's problems with epoxy" - My Wife |
| What if I use 4 (qty) small, 2" (4cm) tabs on each side of the bulkhead then grind them out ? Would that work, or would the point loading delaminate the hull?
| U-joint, CV-joint, Thompson coupling | brian eiland | Propulsion | 20 | 02-13-2012 08:04 PM |
| Transition joint or full length butt joint | unseen wombat | Wooden Boat Building and Restoration | 12 | 06-05-2011 12:16 PM |
| Great Cove 21 | chippah | Boat Design | 0 | 01-18-2009 02:53 PM |
| Temporary Workshop | Brasstom | Boatbuilding | 2 | 05-06-2006 12:37 AM |
| bead and cove stripplanking | trimix | Boat Design | 3 | 10-23-2004 12:01 AM |
