| Best method to takeoff model half hull? I have been lent a antique half hull model which is for my old Rhodes. I was given it so I could produce a similar half hull model and I am looking for the best approach to create a mold from this existing model. The model appears to be a glass layup though seems to have some pure resin on the surface and filling the details. The model has been dropped in the past and has some repaired cracks and chips. Its old. I have the full range of glass, epoxy, fillers, paints, vac setup etc for layups. I have experience- I am in the marine trades. What I am looking for is the best approach to mold the model with the least chance of damage. Currently I am thinking of going the mold release, spray primer & layup shell for a female mold. To build the new model, I would vac down a layup into the mold and presto- new half hull. Is there a better approach? Possibly using some sort of latex mold, or other casting material? There are some fine details I would like to transfer to the mold such as the outline of the rudder and a embossed cove stripe. The half hull is ~ 30" long and is of the classic Rhodes hull form. I will get a photo posted of the model. Thoughts? Thanks all |
| How big is it? Can you make a casting box and do it in RTV? |
| There are lots of ways to pull a mold from a half model. Everything from vacuum formed plastic to plain 'ol plaster of Paris. Latex, polyester or epoxy resin, even Play-Doh or modeling clay can get the job done. |
| A common thing in the movie industry is to use a silicone casting material backed up with a plaster mother mold. Smooth-On Inc is a supplier that has everything needed for casting props. Basically you apply release, cover the thing with one of the flexible moldmaking materials, then build a rigid support with plaster that supports it. The mold slips in and out of the plaster so you can work it off of the original object. A half model should be dead easy. Check out the Prop Forum for ideas and leads. These are a bunch of obsessive amateur nerds that share their ideas. http://www.therpf.com/ |
| Great- thanks all for the replies. I am cautious with this as it has high sentimental value to its owner, is quite old and already damaged. I am just a bit reluctant to use direct GRP molding techniques as a result. That sounds like it might be the ticket BATAAN, thanks. |
| half size PT hull | Larry Wegeman | Wooden Boat Building and Restoration | 20 | 08-08-2008 09:11 PM |
| Melges 24 - 26" Half Hull Model | zumaboat | Marketplace | 0 | 06-19-2008 09:17 AM |
| Win a half model of Ocean Planet | DGreenwood | Open Discussion: All Things Boats & Boating | 0 | 12-22-2006 02:23 PM |
| Confederacy Half hull | Charles Johnson | Sailboats | 4 | 03-08-2004 09:55 AM |
| Lofting from a half hull model | Guest | Boatbuilding | 1 | 11-22-2003 12:12 PM |
