Old 02-01-2012, 03:10 AM
CDK's Avatar
CDK CDK is online now
retired engineer
Rep: 1416 Posts: 2,247
Several good ideas already, especially Hoytedow's dry ice.
I would drill the holes he suggests, but pour hydrochloric acid in them and keep adding more when the foaming subsides. The acid breaks the cement matrix so you can spoon out the aggregate.
This is a time consuming project, but it does work! I know a few guys who silently made a tunnel in rock that way.
Old 02-01-2012, 03:15 AM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1693 Posts: 5,842
I got to ask, if its in the keel and probably the shape of an Ice lolley mold could you not attach a lifting eye and haul it out in one go.
I guess you wont be replacing it!!!
I heard that you can now get spent Uranium that has timed out and is safe. I heard it is extremely heavy, maybe I dreamed it.
Old 02-01-2012, 04:37 AM
keith66 keith66 is offline
Rep: 117 Posts: 223
Couple of GRP boats i worked on had concrete ballast. Wasnt too bad to get out, drilled lines of holes & employed lump hammer & cold chisel. Both boats had bad osmosis issues under the concrete. Just to cheer you up!
Old 02-01-2012, 06:17 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,354
Originally Posted by Frosty View Post
Im not sure if you cant get little dynamites that dentists use for people that dont like drilling.
Little dynamites, huh? Well why the h-e-double hockey sticks not?
Just drill the holes smaller to be a better fit for the sticks!
best method for removing concrete ballast-little-dynamite.jpg  best method for removing concrete ballast-concrete-crackers.jpg
Hoyt
Old 02-01-2012, 06:24 AM
hoytedow's Avatar
Resistor
Originally Posted by robwilk37 View Post
you, sir, are a genius.
There's a fine line between genius and insanity. I have erased this line.
Oscar Levant
(1906 - 1972)
Hoyt
Poured concrete for ballast in a sailing hull..a no no?? Carr Boat Design 28 03-15-2009 03:07 AM
Removing ballast rfnk Wooden Boat Building and Restoration 6 10-01-2008 09:03 PM
Ballast- concrete beam Ari Wooden Boat Building and Restoration 12 02-20-2007 07:37 PM
Is there a problem with concrete as ballast in steel sailboat? hiracer Metal Boat Building 6 07-24-2006 09:01 PM
best method for removing fiberglass itch! Logan Jager Fiberglass and Composite Boat Building 21 08-01-2004 05:15 PM
