Old 04-07-2010, 09:07 PM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,355
Best Bang For The Buck Fasteners
so lets suppose Im working on a motor cruiser with a double diagonal hull, Im thinking I'll be plastic nailing my first layers into place and scewing that last one to my stringers
whats my best fastener for the buck
I could go all out and use silicone bronze
I could get cheap and use galvanized
what are my best options and whats the cost pr K
any thoughts on durability/cost
I am skeptical of the deniers diatribe
Old 04-08-2010, 06:04 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
I haven't build a boat yet, but otherwise have experience. I don't see a reason why good quality galvanized screws wouldn't last, under fiberglassing at least, they just have to stay dry.
Here in Finland I think Stainless screws are a lot cheaper than bronze, don't know if thats the case elsewhere. I've used stainless screws with pressure treated wood, because zinc won't last with the copper- and chromesalts used in the wood.
The small boat I'll build in the near future will have basic electrocoated screws.
Hopefully creating something useful, since 1983.
Old 04-09-2010, 01:56 AM
Stumble Stumble is offline
Rep: 599 Posts: 1,084
I don't know that it really matters, but I would be concerned with about galvinized screws since the zinc might act like a sacrificial anode if you ever wound up in a hot harbor. But I am sure some of the others might have a better understanding.
Old 04-09-2010, 06:49 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,354
Stay away from galvanized screws. They are fine for a barn wall, but moisture gets everywhere. When the zinc is gone the rusting steel screw will swell up like Mr. Big in a Bond movie. Silicone bronze are the best and stainless steel come in second for salt water resistance.
Hoyt
Old 04-09-2010, 04:39 PM
Rep: 1493 Posts: 7,447
Lloyd's would give 15 year rating to galvanized. That means they need a survey or automatically downgrade after. Stainless is worse because of crevice corrosioin. Silicon bronze is the best.
Old 04-09-2010, 04:43 PM
Rep: 418 Posts: 777
Gonzo,
What is the Lloyds rating for stainless?
Old 04-09-2010, 04:48 PM
Zero bellow the waterline. It should never be submerged.
Old 04-09-2010, 08:03 PM
hoytedow's Avatar
Resistor
My ignorance is exposed, but at least I was right about the silicone bronze. Thanks.
Hoyt
Old 04-09-2010, 08:14 PM
Rep: 418 Posts: 777
Just noticed your sig line. LOL, you're not supposed to tug on superman's cape either! Apologies to Jim Croce
Old 04-09-2010, 08:34 PM
hoytedow's Avatar
Resistor
Hoyt
Old 04-17-2010, 02:48 AM
oldsailor7 oldsailor7 is online now
Rep: 269 Posts: 1,118
I have built a number of boats from 25' to 52' using silicon bronze, epoxy coated staples in various lengths up to 2 3/8" long using a power stapler.
The new gas powered hand portable staplers are the best and quickest.
Of course all the joins should be made using Epoxy Glue. The staples are the secondary fastners and are much better than screws IMO.
Old 04-17-2010, 07:54 AM
hoytedow's Avatar
Resistor
Sorry about spelling silicone bronze. I know it should be spelled silicon bronze, but for 19 years I worked at a surgery center where we installed silicone breast implants.
Hoyt
Old 04-17-2010, 12:56 PM
Boston's Avatar
sounds like a fun job
excuse me sir
could you please hold these breasticles for
Old 04-17-2010, 06:57 PM
hoytedow's Avatar
Resistor
We also installed saline breast implants. If you put your ear close you could hear the ocean.
Hoyt
Old 04-18-2010, 11:49 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Wrong saline my friend.
0.9% vs 3.9% but I like the puting your ear to them idea.
-Tom
Buck Marine Diesel timbillyosu Diesel Engines 68 07-17-2009 07:17 AM
Where is the bang-head-against-wall smilie? tinhorn Open Discussion: All Things Boats & Boating 8 03-05-2008 06:26 PM
Simpler stability underway ?low buck, FAST FRED Powerboats 12 06-10-2007 04:11 AM
Simpler low buck, stability underway ? FAST FRED Powerboats 2 07-05-2006 04:05 AM
one bang ployester resin layout ??? newo eloc Fiberglass and Composite Boat Building 8 07-20-2005 12:09 AM
