Old 12-18-2010, 12:40 PM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,036
Bead and Cove Router Bits - Where to buy in USA?
I've been looking around for bead and cove router bits and have come up with nothing.
I have 1" thick foam to bead and cove.
Any suggested vendors?
"You can't solve all of life's problems with epoxy" - My Wife
Old 12-18-2010, 02:01 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
I looked for bits that would join 1" thick materials and I found that there's not much out there. Most every company appears to be completely ignorant of the fact that measurements need to be supplied. They say nothing of radius (which is the vital statistic) because the company is made up of people who know nothing of their product except its catalog number. Welcome to 2010.
I will suggest this: the cove part can be made by running the foam through a table saw on edge, at an angle (as viewed from above--- using a fence somewhat at an angle to the regular rip fence). Any size cove can be done this way.
The bead can be done using a standard round-off bit with a 1/2" radius---- the first edge with the router flat on the panel. The second half with the router on the edge of the panel (otherwise the bearing will ride too deep). Do you understand?
Old 12-18-2010, 02:09 PM
wardd wardd is offline
Rep: 443 Posts: 925
http://woodgears.ca/cove/calculate.html
http://woodgears.ca/cove/index.html
http://woodgears.ca/cove/asymmetric.html
liberty ships were beautiful
Old 12-18-2010, 02:28 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Norton Carbide Tools
5775 Orange Drive
Davie, FL 33314-3819
(954) 587-8665
That is where I get my custom carbide tooling and these as well.
Slippery when wet.
www.cheetahcat.com
Old 12-18-2010, 03:02 PM
Thanks, Alan and Wardd. I do understand the method, but my coves have to be exact and I easily have 4500ft+ of coving (and beading) to do. Damn close to a mile!
I need to do what War Whoop is showing in the picture. Thanks for the referral to Norton Carbide, Mr. Whoop. I'll give them a try.
Old 12-18-2010, 03:20 PM
alan white's Avatar
Great info, Wardd. I know the trick of tilting the saw blade, which I've use to "generate" complex moldings (to match century-old moldings in old houses). I still think the table saw process is as good or better than the router bit method, maybe because I own the table saw and I don't have a mini-shaper. I'm glad someone supplied the vendor for you, any case.
Old 12-18-2010, 04:14 PM
Rep: 84 Posts: 661
Two large routers on a 1" MDF topped Bench, the One shown was the bead, the core box bit was on the other side,it captured the planks and held a exact cove.
Slippery when wet.
www.cheetahcat.com
Old 12-18-2010, 06:01 PM
Rep: 1493 Posts: 7,447
You don't need a 1" bit for 1" foam. A 3/4" will leave only 1/8" square edges which will not be a problem.
Old 12-18-2010, 08:21 PM
Rep: 84 Posts: 661
Go full size
Slippery when wet.
www.cheetahcat.com
Old 12-19-2010, 11:05 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,682
Coves made with a table saw blade are not of a set radius, they are elliptical in shape and so can't be matched with any bead router bit.
Old 12-19-2010, 11:24 AM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1348 Posts: 2,048
Correct, but the difference is insignificant as long as the depth of the cove is reasonable..
Old 12-19-2010, 11:36 AM
Coves made with a table saw are not eliptical but circular. They are not a half circle however, which most half round bits are. There will be more glue needed to fill the gap.
Old 12-19-2010, 11:42 AM
Here's half the problem solved, if you can get a cove to come close to the radius.
Having a wide radius will reduce fragile feather edges on the coves in the foam.
http://www.grizzly.com/products/cate...spx?key=161200
Old 12-19-2010, 12:14 PM
Rep: 84 Posts: 661
The beauty of the system is it's ability to wrap a curved surface with smaller planks and a full size joint is required for this so the planks bead is not raised in the cove through slight rotation off a shoulder creating a unnecessary Putty filled expensive and heavy joint when the core is desired.
The feather edges are fine long as care is used.
Slippery when wet.
www.cheetahcat.com
Old 12-19-2010, 12:20 PM
PAR PAR is online now
Rep: 3125 Posts: 9,391
Considering the linear amount of cove and bead work you need, Catbuilder, a custom bit set is a reasonable option. Personally, I make them up my self, but many don't work metal, know how to weld, have the tools, etc., so a local machine shop can fix you up for not much money.
Fairing Core cel bead and cove brokensheer Boatbuilding 10 12-11-2010 08:22 PM
bead and cove bits shark Wooden Boat Building and Restoration 1 05-29-2008 10:59 PM
bead and cove strips Dijkhuizen Boat Design 52 11-03-2007 12:16 PM
Bead and cove technique / Bilodeau book sailsocal Fiberglass and Composite Boat Building 0 09-09-2006 01:46 AM
bead and cove stripplanking trimix Boat Design 3 10-23-2004 12:01 AM
