Old 04-30-2011, 09:04 AM
whitepointer23 whitepointer23 is offline
Rep: 247 Posts: 652
amphibian
does anyone know of a plan for a home built amphibian, i am thinking about something not to expensive but with reasonable performance . up to 80km on road and 10 knots on water. not a banana split buggy. maybe it could utilise a small 4wd chassis like a suzuki with a pto for propellor.
Old 05-01-2011, 03:19 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
I havnt come across any - but I would be keen to hear of one as well.
There are a heap of threads in this forum about the topic, lots of links and ideas but I can hardly recall any current production models, let alone plans.
The 'amphibious buses' seem to be building a few, but the all get into the $200,000 mark - like a Winnebago.
I do know of one guy in the north of australia that attached polystyrene floats to each side his Suzuki 4WD, and it floated fine - so it must be doable.
Old 05-01-2011, 03:50 AM
EuroCanal EuroCanal is offline
Rep: 82 Posts: 75
The UK kitcar company Dutton sell a kit to make an amphibious car. The kit costs UKP 7,000, and you must find a Suzuki Jimny or similar as a donor vehicle.
Their site is http://www.amphibiouscars.co.uk
The maximum speed is about 5 knots in the water. It's pretty basic - probably not great as either a car or a boat.
Old 05-01-2011, 04:08 AM
Rep: 247 Posts: 652
thats the style i am thinking of. i also thought of a suzuki sealed on the bottom and with detachable catamaran floats. it could carry the floats on a roof rack or maybe they could swing onto the roof with some sort of hinge system.
Old 05-09-2011, 07:53 PM
rwatson's Avatar
I notice Dutton is offering free 'inspections' on old vehicles to check for rust etc.
The hardest bit is sealing the drive components. Imagine a boat trailer left in water for 2-3 hours, the bearings would die very quickly.
Ideally, you need some way to raise the drive gear.
Old 05-09-2011, 11:28 PM
Rep: 247 Posts: 652
it would be a major concern, but i think if it is hosed off and sprayed with lanolin after each trip you should be able to keep it under control. the front wheel bearings might be a problem unless you could convert them to oil filled.
brendan .
Making an amphibian more seaworthy. alexlebrit Boat Design 2 10-24-2006 12:49 PM
