Old 12-05-2011, 11:01 AM
Manie B's Avatar
Manie B Manie B is online now
Rep: 1474 Posts: 1,620
Alternator
Gents the question is
has anybody tried to build their own "towing alternator"
http://www.ampair.com/
Rory McDougall used one successfully on "Cookie" in the last Jester Challenge
http://roryandcookie.blogspot.com/se...max-results=50
YouTube has dozens of videos of a lawnmower engine driving an alternator via a belt, and they work well
but I cant find ANY example of someone trying to drive it by towing a propellor on a long shaft
the lawnmower systems are cheap and do the job, why not try to tow it?
here is the PDF of Ampair brochure
see page 7 and 8
Bye bye Folks - off to see the world ~~~/)~~~ :)
Compulsive Neurotic Manic Depressive,
but basically happy :)
http://compaxboats.wordpress.com/
http://www.boatdesign.net/forums/boa...ser-27869.html
Old 12-05-2011, 11:17 AM
Rep: 670 Posts: 2,457
Seen many tow alternators , but never a home made one. The website Yachtwork has some ideas
http://www.yachtwork.com/report-wind.htm
http://www.yachtwork.com/images/repo...ade%20plan.jpg
The high tec towing alternators that the round the world racers use might be worth study.
http://www.wattandsea.com/
Old 12-05-2011, 02:13 PM
Manie B's Avatar
Michael thanks
the first link actually has plans on how to build one - great stuff thanks
Old 12-05-2011, 05:54 PM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,355
they use a slightly modified alternator in many of the available wind turbines, works like a charm. so no reason at all you couldn't do exactly what your talking about. Except I'd only want to throw it out once I was parked and let the current drive the prop. That way your no burning fuel to drive the thing. Also someone came up with a wave powered generator. Was a number of hinged sections geared to a drive unit. Every time they flexed the energy was converted into driving a shaft that drove the alternator. They just rewound the rotor, or was it the stator, can't remember but one of them was rewound and presto. Worked like a charm.
I am skeptical of the deniers diatribe
Old 12-06-2011, 02:44 AM
CDK's Avatar
CDK CDK is online now
retired engineer
Rep: 1416 Posts: 2,246
Most people want to reduce drag to a minimum and use folding props, self polishing anti-fouling etc. to achieve that. If that is not your concern, install an alternator that is belt driven from the prop shaft, it is more reliable than something towed behind the boat.
If you want to experiment without spending a lot of time: there are propulsion devices for swimmers and divers, employing a permanent magnet motor in a torpedo shapes housing. Mostly cheap stuff made in Asia.
Remove the batteries, make a watertight cable connection and tow the thing behind your boat. They are small in size, so do not expect fast charging!
Old 12-06-2011, 03:17 AM
The problem with shaft alternators is that Manies boat is so small. Ive used dc alternators, belted off free wheeling prop shafts , my whole life. They work very well.
A very low friction stern tube is needed . This implies an oil bath, roller bearing , thrust bearing, shaft tube. Expensive . Also investigate whether your gearbox can free wheel without damage. Twin disc works fine. I dont know id Volvo style legs can be used with an alternator.
Additionaly the physical space between gearbox shaft coupling and stuffing box must be big enough to get the alternator in.
On bigger boats the free wheeling prop shaft geerates DC and when fitted with a additional belted hydraulic pump...hydraulic pressure to power the auto pilot rams. A very robust system
If you have the space , its well worth exploring the shaft alternator idea. They are durable because they are protected from the elements and effective when shaft free wheeling or motorsailing
Old 12-06-2011, 08:20 AM
Manie B's Avatar
The plus point of the towbehind is that it is easy stowable, easy de-ployable and when stowed, no friction.
I read a piece on towing at 6 amps all night long
that is fantastic because the lights etc. has very little drain on the batteries
for me it is a very valuable backup
6 amps is plenty for me
my solars will only deliver 2x2amps x 5 hours = 20amps per day on a good day
12 hours of towing could give a huge 72 amp/ hours
and thats pretty cool for 15kg pull
I bought a 55 amp 12v alternator new for ZAR587 = US$73
a 2 amp 35w solar panel was ZAR773 = US$96 EACH
prices includes VAT14%
small new 5hp fourstroke engines are around ZAR1400 = US$ 175
so I got the motor and alternator and will build it as soon as I have the boat on the trailer
will keep you guys posted
I will definately experiment with towing as well
Old 12-06-2011, 08:35 AM
Just like a tafrail log, big Fish will bite the towed prop. Make a break link so the shark doesnt take your whole rig with him.
You might investigate the shape and efficiency of a walker log type towed prop
Old 12-06-2011, 10:42 AM
Boston's Avatar
There is a company called Windblue that makes alternator stators for low speed conversions of alternators
http://www.windbluepower.com/
you might find some useful stuff there.
Old 12-06-2011, 11:25 AM
Manie B's Avatar
Here is a paper that was written on this kind of installation
very informative
http://web.media.mit.edu/~nathan/nep...lternator.html
it also deals with "low rpm"
Old 12-06-2011, 11:29 AM
Manie B's Avatar
jeez I loved the "steam engine"
the thing "wobbles" like crazy
http://www.windbluepower.com/category_s/56.htm
Old 12-06-2011, 11:31 AM
Manie B's Avatar
You know this is good
I have found no other reference to this problem
good one, thanks
AC or DC alternator simon OnBoard Electronics & Controls 33 03-06-2011 02:24 AM
Alternator Question wallacemag OnBoard Electronics & Controls 3 08-29-2010 09:53 AM
need a new alternator powerstrokeaaro Propulsion 2 05-02-2010 03:59 PM
Alternator alternative?? steveroo OnBoard Electronics & Controls 13 01-01-2010 11:59 AM
How do you see if alternator is charging? mr300s Powerboats 7 07-15-2006 09:54 PM
