Old 12-29-2005, 08:19 PM
zoso zoso is offline
Rep: 10 Posts: 13
Originally Posted by jacquesmm
Why don't you ask the designer? He responds in a few hours at his message board:
http://www.bateau2.com/index.php
OK, I'm the designer.
Short answer: don't do it.
Longer answer: don't do it because foam sandwich is not a valid option in such a small size. It will be heavier than the plywood shown on the plans.
If you insist, limit the damage by using for example Divinycell H45 with one layer 1208 each side.
More:
- that little boat is sensitive to excessive weight in the topsides, another reason not to do it.
- it's expensive and labor intensive.
- I designed my 1st foam sandwich boat in 1976 and know the material very well, better than most. It's not for small 16' cruising sailboats.
Ok, thanks heaps for all the advice from everyone. I was just exploring ideas and ways of keeping costds down and keeping the boat as light as possible. I'm glad I got to chat about it here before getting into anything!
So while I have the attention of the designer, how might I go about keeping the deck as light as possible, if as you say its sensitive to weight up top??
Old 01-06-2006, 07:55 PM
PAR PAR is online now
Rep: 2891 Posts: 8,796
The basic point everyone has been reasonably nice about beating 'round the bush is, unless you have substantial engineering skills, which your previous posts haven't revealed, then building to the plans would be your most reasonable course of action. Make changes to the areas of the boat you would find of more convenience, rather then structure, unless of course, you are capable of engineering panel loading or center of masses calculations to effect a successful outcome in your redesign of this craft.
Old 01-06-2006, 09:32 PM
Robjl Robjl is offline
Rep: 10 Posts: 90
Stick to the plans...
Best advice I can give is to suggest you stick to the plans.
You don't have the engineering or experience with materials to go off on a tangent.
Your ideas as explained in your first post are not sound.
Try your local wholesale suppliers/resellers for some "Hoop pine C-C structural ply" if the price of marine ply is too high for your budget, it's less than half the price of marine ply, the glue line is waterproof and the timber the same as marine ply. The surface finish won't be as good as marine ply and the structural ply will have some minor defects (cracks/voids in the internal veneers) that aren't really a problem in a project like yours.
I know you think that the 16' is your size...I know several people who moved up to an 18' boat...the difference in size ..16' to 18' is significant...the 18 is a much better boat in my view for not a lot more work.
Check out your local yacht clubs (where trailer sailers race)...I'm sure an afternoon visit and a chat with owners (who will all offer good advice) would be worthwhile.
Which State are you in?
Cheers
Rob.
fiberglassing plywood boat deck KMD Materials 11 11-10-2005 12:49 AM
Boat Stability help pls. trouty Boat Design 11 10-28-2005 11:55 PM
Building My Own Boat 66hemi Boat Design 1 10-08-2005 11:51 AM
need help building custom boat mini_man91 Boat Design 2 05-30-2005 06:59 AM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 11:08 AM
