Old 03-20-2011, 03:27 PM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,036
About To Lift Hull From Mold - See Anything Wrong??
Here are a couple of pictures that how how my lift is set up. I have:
*Temporary bulkheads at the even stations of my mold
*Temp bulkheads are held in by ratchet strap (yellow)
*Temp bulkheads have small, 4" (10cm) coves in 3 places to help hold them. These little coves are on the other side of the bulkheads, facing away, so you don't see them in the picture.
Larger lifting straps will go where the yellow drawn in lines are in these pictures.
**Note: There is only a bilge from station #6 to station #16. No deck, just a tiny topsides and a bilge. This is one of the half hulls where the bridgedeck connects. This is making me quite nervous.
I plan to run longitudinal members all along the temporary bulkheads in the positions indicated by the two red lines. The one to the left in the picture will hopefully keep the hull from folding up like a "C" shape laying on the ground. The one in the middle will hopefully keep it from folding up like a "C" shape with the bow and stern in the air and the middle on the ground.
Anyone see any problems, before I lift it, snap it in half and throw it in the dumpster??
About To Lift Hull From Mold - See Anything Wrong??-lift1.jpg  About To Lift Hull From Mold - See Anything Wrong??-lift2.jpg
"You can't solve all of life's problems with epoxy" - My Wife
Old 03-20-2011, 03:42 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,354
Put the narrow edge of the stringers against the bulkhead edges to take advantage of increased stiffness.
Hoyt
Old 03-20-2011, 03:47 PM
Good idea, Hoyt. Will do.
Think I can get away with 1x2's, or do I need to go to the store and pick up 2x4's?
Old 03-20-2011, 04:10 PM
hoytedow's Avatar
Resistor
2x6's. This is not the place to skimp on materials, and you may need them later.
Hoyt
Old 03-20-2011, 04:15 PM
hoytedow's Avatar
Resistor
2x4's will probably work but any job worth doing is worth overdoing.
Hoyt
Old 03-20-2011, 04:19 PM
Ok, I'll go pick some up tomorrow. Thanks.
What about putting coves on the side of the bulkheads that is facing the camera?
If you go to try and fold this thing up so the bow and stern are up and the middle is sagging, could that bend some of these bulkheads away from the side without a cove and toward the side with the cove? That would cause them to tear out, I think...
Old 03-20-2011, 04:28 PM
hoytedow's Avatar
Resistor
Temporary blocks with tightly fastened small c-clamps on both sides of bulkheads should keep them from pulling across their planes. You could place 1x2's here that reach from bulkhead to bulkhead. Drawing to follow shortly. Colored line will represent 1x2.
What do you think?
You can never own too many clamps!
Hoyt
Old 03-20-2011, 04:40 PM
Too expensive, Hoyt...
I have plenty of clamps, just not that particular type. I'd have to go and buy another 36 clamps just for this lifting project.
Wouldn't it be cheaper (and just as effective) to duplicate my little bog spots on both sides of the bulkhead?
Also, just noticed that I can't do the c-clamps anyway. The mold battens are in the way for that.
BTW: How do you do these drawings?!? Are you hand drawing them and scanning them?
Old 03-20-2011, 04:43 PM
hoytedow's Avatar
Resistor
That's true, but if you saved the receipt and took them back for a refund undamaged, what have you lost?(Not that I would ever do that) Small clamps 1.5" are very cheap. You know, the little metal ones that say china on the sides.
Hoyt
Old 03-20-2011, 05:07 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
What are you lifting this with? If some sort of crane make a spreader bar almost the full length of the hull. To do this you need to glu up two opposing 2x6s--one flat and one nailed in vertical like an L. each piece being a 2x6. spice them together and add a scab at each joint 36"-2x6. Use 4 lifting points eye bolts are fine. there will be little if any flex but the flat 2x6 must be secured to the hull at each bulkhead--a strong connection....This is called a strongback and is used where ceiling joist are over spanned. You can use strong channel or even angle stock to equal out the lift. This is stronger then the method Hoyt drew out.
Old 03-20-2011, 05:48 PM
hoytedow's Avatar
Resistor
Some I hand draw. Some I draw in paint on computer. Latest drawing I did was to draw an ellipse, chop off the top, copy it and reduce it several times and line it up on two black lines to give perspective. Easy Peesy.
Hoyt
Old 03-20-2011, 05:55 PM
hoytedow's Avatar
Resistor
Originally Posted by rasorinc View Post
What are you lifting this with? If some sort of crane make a spreader bar almost the full length of the hull. To do this you need to glu up two opposing 2x6s--one flat and one nailed in vertical like an L. each piece being a 2x6. spice them together and add a scab at each joint(on both sides of bulkhead to avoid shifting) 36"-2x6. Use 4 lifting points eye bolts are fine. there will be little if any flex but the flat 2x6 must be secured to the hull at each bulkhead--a strong connection....This is called a strongback and is used where ceiling joist are over spanned. You can use strong channel or even angle stock to equal out the lift. This is stronger then the method Hoyt drew out.
Put the blocks on the underside of the 2x6 all the way down will keep all the bulkheads at set distance.
Hoyt
Old 03-20-2011, 06:17 PM
Be back on in a moment. For now... here is a picture of what I'm lifting the hulls with.
I have a pair of these... one for each lift point. I planned to lift it with slings, just like a Travelift:
Old 03-20-2011, 06:24 PM
hoytedow's Avatar
Resistor
My last sketch of course shows the 2-by upside down for illustrative purposes. Each bulkhead braces all the rest so no one bulkhead takes all the strain. It is also drawn without the side piece(which makes it L-shaped. Here is another.:
Hoyt
Old 03-20-2011, 06:49 PM
That should work. I would use 2 straps for each crane giving you 4 lifting points.
rent 100-110ft mold for sailing yacht? or someone can build hull from own mold for me gp333 Boat Molds 19 10-05-2009 08:27 AM
Hull Mold thert Boat Molds 4 03-12-2009 10:09 PM
Need Hull Mold thert Boat Molds 0 02-07-2009 09:41 AM
how to give a hull bow lift weehenry Boat Design 18 10-12-2008 07:23 PM
extending hull to gain lift schecter Powerboats 5 08-04-2004 01:54 AM
